Fog Lights Aren't Working - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 05-23-2005, 11:39 PM Thread Starter
YoungExec728 is an unknown quantity at this point
What's up guys? This happen pretty recently. My fogs used to work perfectly, but all of a sudden they stopped working. When I push the button to turn them on nothing happens, the indicator light on my dash doesn't even light up. I can still turn on/use my high beams so that has nothing to do with it. I checked all the fuses and they are all fine. I know it's not the H1 bulb because the indicator light is not lighting in the dash and it still would even if the bulb was burnt out. Also, I hooked up the fog lights to a spare 12V battery I have and it worked fine.
I have noticed in the past that when I push the button to turn on my fog lights there is a clicking sound that occurs under the hood near the fuse box. I'm assuming that its the relay to turn on the fogs. But since they stopped working there is no more clicking sound.
To me it sounds like it may be the relay. Does anyone know which relay it is and where I can get a replacement? Also, could it be something else that I may have overlooked? Thanks
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline
post #2 of 14 (permalink) Old 05-24-2005, 02:00 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
is it possible for you to check the relays? if your not familar with them than i suggest taking it to a pro, but if you wish you can try i believe the relay your looking for is the middle one, but do some research first before messing with it.
Furious is offline
post #3 of 14 (permalink) Old 05-24-2005, 09:52 AM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
Ok... yes... it is most likely your relay... the relay is located in the front left distribution box... same place your fuses are for the fogs. If you look on the bottom of the distrubution top cover there should be a layout. If not.. try searching the site for "front distribution" I have posted pictures of a fuse and relay layout before... I would go take another picture but I'm in Iraq... its on the outboard side and its orange if I'm not mistaken...
If you have an electrical test set you can cycle the switch on the inside of the car... if you have power coming out of one of the (4) prong inserts then you are sending power to either the ground or either the fogs themselves. If your not getting any power from the relay points... then you have a faulty relay. The system sends that ground if I'm not mistaken to a grounding point and to the light in the dash. So if you dont have power being transfered through the relay.. it wont end up to the ground because the power goes through the relay before it hits the ground... once a ground is cleared is proceeds to send the power to the fogs.
Another thing you can do is take the back of the fog lights off and test the electricle connectino to the for lights them selves. Probably a waste of time here due to the fact that your not getting a fog indication on the dash which comes from the relay.
If you can not find the diagram on this site... try a search for "e36 front distribution box" on www.google.com
Good Luck,
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #4 of 14 (permalink) Old 05-24-2005, 10:05 AM
The attachment should show witch relay and the pin assignments are:
Term 30 Pin 6 = Main power feed
Term 85 Pin 4 = Earth
Term 86 Pin 8 = Feed from switch
Term 87 Pin 2 = Feed from relay to warning light in cluster
Term 87 Pin 5 = Feed from relay to front lights via fuse 15
The terminal numbers are mark on the relay and the pin numbers are on the block connector
Id have a look at the switch as well
bad man working is offline
post #5 of 14 (permalink) Old 05-24-2005, 10:12 AM
Been here a while.
97alpineM3's Avatar
Someone either has a ETM or a nice manual...
Where did you get that info?
Les
post #6 of 14 (permalink) Old 05-24-2005, 10:15 AM
Ive been fixing BMWs for over 20 years
post #7 of 14 (permalink) Old 05-24-2005, 10:19 AM
e36surge's Avatar
Relay is $31.00 CD$ at the dealer
Part number 61 31 8 353 448
I like 'bad man'
e36surge is offline
post #8 of 14 (permalink) Old 05-24-2005, 10:24 AM
Been here a while.
97alpineM3's Avatar
Might just be crazy here... but my distribution box is totally different... if that matches... go with it.
Les
post #9 of 14 (permalink) Old 05-24-2005, 10:51 AM
my car is red
94BMW325i's Avatar
94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of
Maybe m3 is different then?
94BMW325i is offline
post #10 of 14 (permalink) Old 05-24-2005, 11:43 AM
e36surge's Avatar
M3 boxes are different.
Gices us a heads up if the relay worked.
e36surge is offline
post #11 of 14 (permalink) Old 05-24-2005, 11:55 AM Thread Starter
Thanks for all your help guys!! My distribution block is different as well, but from the research i've done I believe that it is the same relay. I am very familiar with testing relays (I started off years ago in car audio) so I going to try that out first and see if I am getting power out of the relay. If that's the problem then i'll replace it, if not, then back to the drawing board.
Thanks again for all the help. It's good to be party of a quality board without all the BS.
post #12 of 14 (permalink) Old 05-25-2005, 01:57 PM
Been here a while.
97alpineM3's Avatar
Werd to that.... tell us how it goes..
Les
post #13 of 14 (permalink) Old 04-26-2010, 12:54 PM
armin325i is on a distinguished road
hi there
i am facing the same peoblem the fog light not working with the low beam i have changed the big green fuse but i still have facing the same problem please help
armin325i is offline
post #14 of 14 (permalink) Old 04-26-2010, 01:22 PM
Quoted: 1 Post(s)
Thread too old; from 2005
witeshark is offline
Closed Thread
Fog Lights Not Working tagerman 3-Series (E36) 4 04-26-2010 12:45 PM
Abs,asc Lights On + Speedo Not Working ghazanfer 5-Series (E12,E28, E34, E39, E60) 2 06-06-2005 12:55 PM
E30 325ic - Reverse Lights Not Working ///Matt 3-Series (E21, E30) 1 01-10-2005 05:02 PM
2000 323CiC License Plate Lights Not Working seelinger 3-Series (E46, E90) 0 06-01-2004 06:31 PM
reverse lights suddenly stoped working mstar 3-Series (E36) 5 05-28-2004 07:16 PM
