fog light wiring problem - BMW Forum - BimmerWerkz.com
Old 05-16-2003, 11:50 AM   #1 (permalink)
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
well, my pass side fog light does not work, there are 3 wires that look to be cut, i hooked the two i thought were the right ones up, and when i did, they brights stayed on constantly and went off and on by the fog light switch and that fog light never came on...but they work fine(the brights) with those wires un hooked...could i just branch off of the driver side light and run wires across? will the voltage be a big difference? if that will work i would like to do that...thanks!
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline   Reply With Quote
Old 05-16-2003, 11:56 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
your crazy hehehe :lol: , dont branch anything . get your voltage tester out and track down the problem. if not get er' fixed when you get a buck or two. it could just be lose wire in the clip connector that is messed.
Old 05-16-2003, 08:52 PM   #3 (permalink)
Scarface's Avatar
yeah i would rather do it the right way, there is no plug in the back of the fog light that isnt playing, so im gonna test the 3 wires that are cut and see if i can make the one work that i didnt use....i did a print out on our computer at work that we use to do alarms but it never gave me the wire color for fog lights, just parking and headlight...
Wiring Problem chardotcom 3-Series (E36) 5 03-16-2009 06:52 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Heated Seat And Tail Light Problem MadBMW M-Series (M1, M3, M5, M6) 1 03-17-2005 08:54 PM
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 08:49 AM
Problem with signal indicator light ye12 3-Series (E21, E30) 4 09-02-2004 11:34 PM
