Fog light problem HELP! - BMW Forum - BimmerWerkz.com
Old 10-08-2006, 11:54 AM   #1 (permalink)
Tochenzo's Avatar
Tochenzo is an unknown quantity at this point
Send a message via AIM to Tochenzo
Ok so my driverside foglight went out a few weeks ago, I changed the bulbs around and found out it was a bulb that was out. The burnt bulb is on the passenger side now and the old working bulb is on the driver side. I replaced the burnt bulb with a new one and everything was working, then later last night the passenger side fog light (side that i put the new bulb in) went out again. I checked the bulb, the filament and everything looked fine on both bulbs so i checked to see if it was a fuse/relay issue. Fuse looked fine, even put in a new one just in case, and the relay looked fine (not sure how to check the relay for working order). I put up a volt meter to the brown/yellow wires leading up to the fog light housing to see if it was a wiring problem, both sides put up 12 volts consistantly. The green light in the dash turns on and everything, what is going on!??!?!
Sometimes when I press the fog light button, the green light flickers before turning on or doesn't turn on at all until I press it a few more times (this has always happened so i don't think it's the cause of any problems). Also, when I press the fog light button, there is a clicking sound coming out of the fuse box. Does this mean it could be a relay issue?
Everything seems to be working up to the housing, yet my fogs still won't turn on. And the housing seems fine because the bulb is in securely and everything is plugged in. Could it be a bad ground somewhere?
Tony
National Capital Chapter BMW CCA #367673
1998 Hellrot 328i
Tochenzo is offline   Reply With Quote
Old 10-08-2006, 06:58 PM   #2 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
try some dielectric grease on the contacts...there maybe some corrosion in there. if there is 12v to a working bulb than it has to work...also sounds like your foglight switch is starting to stick. there was a thread just a little bit ago about how to clean out the inside of the switch. in short check continuity in the switch and put some dielectric grease on the bulb contacts.
polaris448 is offline   Reply With Quote
Old 10-09-2006, 10:54 PM   #3 (permalink)
Tochenzo's Avatar
so you don't think it has anyting with the actual wiring? ground, bad wire, etc?
Tony
1998 Hellrot 328i
Old 10-10-2006, 12:43 AM   #4 (permalink)
polaris448's Avatar
how would you have tested 12v with a bad ground?
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
How to replace fog light bulbs??? Ocean02 3-Series (E46, E90) 7 02-05-2006 02:55 PM
Can Fix My Air Pump Problem, Check Engine Light Esme 3-Series (E36) 1 05-05-2005 12:33 AM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
