Fluid Questions - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 06-05-2005, 01:02 AM Thread Starter
I've got a couple road trips coming up, and want to change my fluids.
How much oil do I need?
How much oil do I need for the transmission, and which red line oil should I get? Any tips or tricks when changing, I plan on changing the filter at the same time?
How much oil do I need for the differential, and again, which red line oil should I get?
If it helps, I have a 97 328is and live in upstate NY, car is driven in the winter. I've heard guys say that their transmissions shifted much better in the winter with red line in it.
wulley1 is offline
post #2 of 4 (permalink) Old 06-05-2005, 06:28 AM
All BMWs since about 1990 dont need auto box filter changes. As to oils Id always recommend using what the manufacture recommends, these are marked on the boxes itself. On a 1997 car you box may well be lifetime oil and doesnt require changing.
Im a Brit and havent heard of redline, I always use Castrol oils as theyre recommended by most manufactures.
If your oils are changeable:
Auto box = Castrol dexron III Approx 5lt
Standard Diff = Castrol SAF OX Approx 1.5 2lt
Limited slip Diff = Castrol SAF XJ Approx 1.5 2lts
Or look at www.castrol.com
bad man working is offline
post #3 of 4 (permalink) Old 06-05-2005, 09:32 AM
quality
Delmarco's Avatar
Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute
BMW has the reccomended oil type to use for eE36 cars. Go with that it will be the best. In terms of how much oil you need for fluids is determined by how much is in there already. Adding fluids in sometimes not the best way to service your car. You may need to flush out old fluids completely, clean the containers out of any residues and pour in new fluids.
Delmarco is offline
post #4 of 4 (permalink) Old 06-06-2005, 07:16 AM
Super Moderator
dutchbmw's Avatar
dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute
Enter your VIN in the box: http://www.bmw-z1.com/VIN/VINdecode-e.cgi
It shows the most required information!
BMW '96 M3 (SOLD
June 2005 Car Of The Month!
Originally Posted by Torque
dutchbmw is offline
ATF oil? sanjose 5-Series (E12,E28, E34, E39, E60) 3 02-01-2009 01:35 AM
Anyone Good With Fluid Leaks? Could It Delmarco 3-Series (E36) 14 11-08-2004 09:51 PM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Power Steering - PS fluid or ATF Jmiller911 3-Series (E21, E30) 2 06-15-2004 09:16 PM
Tranny Fluid and Rear gear oil Questions... BMWStrat 3-Series (E36) 2 03-23-2004 03:33 PM
