Final Stage Unit - BMW Forum - BimmerWerkz.com
Old 10-24-2004, 03:00 PM   #1 (permalink)
Climate control in my car won't start blowing air for about ten minutes when the car is started. Tried doing the DIY fix, but that didn't fix the problem either. I've heard of a lot of people replacing the final stage unit.
What exactly does that do?
Old 10-24-2004, 06:46 PM   #2 (permalink)
come on, some body must know what it does. Has anyone else replaced theirs?
Old 10-24-2004, 11:21 PM   #3 (permalink)
RallyE36 is an unknown quantity at this point
The final stage resistor controls the fan relay by measuring the amount of flow and temperature requested by the climate control unit. When not functioning properly the fan relay gets confused and won't know when to control the fan.
It is an easy replacement.
Part = $127.00 CDN at the dealer. I suggest buying new as a used one will simply fail that much faster.
The resistor is located just to the right of the accelerator (gas pedal) behind some wiring harnesses. I found difficult to see it at first, as it is very crowed under there.
Look at the back of the new one, then look for the same shape with the plug end.
Unplug and unscrew the existing and replace with new.
This is a sealed unit, so I wouldn't even attempt at trying to fix it.
Good luck.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 10-25-2004, 01:21 PM   #4 (permalink)
RIBEMR26's Avatar
Read one of my threads...I just replaced mine...cost = $100 at Bavauto and it took about ten minutes to fix...BMW wanted $250 for this one...
http://www.bmw-forums.com/forum/index.php?...03&#entry184503
Clear Corners and Sidemarkers
Old 10-26-2004, 12:32 PM   #5 (permalink)
I wonder if that would cause my fan to not blow when the car is started up?
Old 10-27-2004, 03:27 PM   #6 (permalink)
ex owner/admin
Furious's Avatar
thread edited. please dont bring that type of talk on the forum again. or its instant ban.
Old 10-28-2004, 11:42 AM   #7 (permalink)
ya, the thread got out of control for no reason.
Anyone Need A Final Stage Unit For 97 318i? jroberts312 3-Series (E36) 2 06-16-2005 09:40 AM
Final Stage Unit wulley1 3-Series (E36) 5 03-20-2005 10:45 AM
Diy On Final Stage Unit SuperFreaks 323is 3-Series (E36) 1 03-04-2005 07:17 PM
Final stage unit failing? Can you repair it? jroberts312 3-Series (E36) 13 11-10-2004 10:41 PM
Fan/Blower Unit failure - final Stage Resistor? badaxe 3-Series (E36) 0 07-16-2004 03:56 PM
