A few problems and questions - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 01-23-2004, 04:33 PM Thread Starter
JeremyMarkham's Avatar
JeremyMarkham is an unknown quantity at this point
Send a message via AIM to JeremyMarkham
Hey everyone . I am new here and let me first off say hello to everyone! I look forward to sharing information, etc. I just inherited a 1993 BMW 325 4 door. Red in color, black leather interior. Overall a nice looking car but there are a few problems.
My first problem is that the rear right passenger window wont roll down. All 3 other windows work except for that one window. Any ideas on how I should go about solving this problem? My next problem is acceleration. When driving, the acceleration sucks VERY sluggish. I mean, I floor the pedal and the acceleration is as if I am lightly pressing on the gas pedal. No take off at all. What could be the problem? My final problem is that I am going to be adding aftermarket speakers and was looking for a picture write up on how to go about doing that. BTW, why are there 2 "mini" speakers on the front door panels? I know that at least one of them (on each door) is a tweeter. But the other ones?
In case you were wondering I inherited this car from my uncle who moved out of the country and left the car to me. I currently drive a Nissan Maxima (99) and would love to fix up this BMW. I sincerely apreciate any help, info, links, etc that anyone may provide! Cheers!
"The whistles go WOOOOOOOOO!"
JeremyMarkham is offline
post #2 of 8 (permalink) Old 01-23-2004, 05:51 PM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
first off welcome, secondly, if you havent given the car a tuneup since youve had it , i suggest doing so to clear up any problems it may have.
the window could be the motor or relay,
the two mini speakers are the tweeters.
Furious is offline
post #3 of 8 (permalink) Old 01-23-2004, 06:08 PM
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
welcome brother..... I can say that you are going to want to upgrade to speakers from the line of Harmon Kardon, or MB Quartz, as they are known for BMW's and aftermarket replacements as well as the fitment of the speakers are almost perfect.... as for acceleration, I would definitely take the car to a BMW dealership if you do NOT have a mechanical side to you with cars, as they do get complicated. Otherwise I would do a complete tune-up on the car, including new spark plugs, wires, distributor cap as that was a problem for these early model E36'rs, change the oil, filter, air filter.... along the lines your car might throw out a CEL or you might correct this with just the tune up.. whatever you do, good luck and hope you enjoy the forum...
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='
target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='
bimmerfan620 is offline
post #4 of 8 (permalink) Old 01-23-2004, 06:39 PM
BMWL2's Avatar
BMWL2 is an unknown quantity at this point
Send a message via AIM to BMWL2
Motovated Motorsport Forums
BMWL2 is offline
post #5 of 8 (permalink) Old 01-23-2004, 11:40 PM
TECH's Avatar
For the windows, try swapping the window switches around to see if the window will work with a known good switch.
Also, and be careful doing this, is to slam the door hard, as this sometimes gets the window motors to start working....or if you know where the window motor is located, bang on the door panel with your hand, but don't break anything..
No power out of an engine could be any number of things. Even the catalytic converter could be stoppedup. You can pull the oxygen sensor out (before cat) and drive it to see if it greatly helps, but it'll set a check engine light before long.
Check the air filter.
TECH is offline
post #6 of 8 (permalink) Old 01-24-2004, 01:51 PM Thread Starter
Thanks for all the info. Where would you all recommend I take my car in for a tune up? I am thinking the dealer but I am afraid I may get bent over. What would the dealer charge for such a tune up? I am going to be spending the day doing a few basics, oil change, filter change, and spark plug change...Which bring me to my next question? What spark plugs do you recommend I use? I had Bosch Platnium 4 in my Maxima and I have heard that for Japanese cars, Bosch is not the way to go. But for German cars, its a . What would you use? Anyway, I aprecaite all the input I have gotten so far. Thanks again!
BTW, bimmerfan620...Where would I be able to find Harmon's and MB speakers for this car? I called Best Buy and the guy I talked to didnt know what he was doing.
&quot;The whistles go WOOOOOOOOO!&quot;
post #7 of 8 (permalink) Old 01-24-2004, 05:50 PM
eloff19's Avatar
eloff19 is an unknown quantity at this point
Send a message via AIM to eloff19
i'd recommend ebay for audio, i've had good luck and saved quite a bit of money
eloff19 is offline
post #8 of 8 (permalink) Old 01-25-2004, 08:29 AM
Threadkiller
bitcore's Avatar
bitcore will become famous soon enough bitcore will become famous soon enough
Audio: Cadence A7+HC mono amp, Cadence A4 - 4 channel amp, Alpine CDA 7995
Get some nice speaker replacements if you are an aduio nut, otherwise you *might* be alright depending on what's already in there, especially if your on a tight budget.
bitcore is offline
Buying First Used Bmw, Have Some Questions ynotony 3-Series (E36) 1 06-06-2005 04:17 AM
Bmw, Typically Big Engine Problems? BMW-ATI 3-Series (E36) 41 05-22-2005 10:38 PM
Idle Problems '95 325is Burnettm 3-Series (E36) 3 04-26-2005 01:41 PM
Electrical Problems And Other Newbie Questions 325eXTATIC 3-Series (E21, E30) 4 03-31-2005 10:35 AM
I have some questions kato 3-Series (E46, E90) 0 03-31-2004 02:24 PM
