Fault codes i have a 95 325is and lately the idle has been screwed up
about every 20-25 seconds the rpms drop almost enough to stall the car and then it rebounds itself
now i recently purchased the peake research scan tool
so i scanned it and i found 4 codes had been set
problem is im not even sure where to start throwin parts at different things
i came out with:
-Output stage, Group 1
-Knock sensor, cyl 4-5-6
-Knock sensor, 1-2-3
-Knock control test pulse
im happy that i have found the codes but still im not sure where to begin
hopefully some of you have any info at all on these codes cause to me they arent making sense, like should i throw some knock sensors in first seeing as 3 of the codes mention knock sensors? but besides that i dont know what output stage even means
well thanks for taking the time to check this out
later |
