Fault Code Reader - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 03-01-2005, 08:43 PM Thread Starter
Berryman is an unknown quantity at this point
Just bought my 328i. The guy that sold it to me gave me a Bavarian autosport code reader, but it did not come with the list of fault codes and explanations. Can anybody help me with a list and instructions how to use it? It looks like there were instructions on it, but now they are worn off!
1996 BMW 328i
Berryman is offline
post #2 of 4 (permalink) Old 03-01-2005, 09:29 PM
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
328i what year ?
what you figure out?
aheath is offline
post #3 of 4 (permalink) Old 03-02-2005, 05:29 PM Thread Starter
96'
1996 BMW 328i
Berryman is offline
post #4 of 4 (permalink) Old 03-02-2005, 06:25 PM
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
DME Control Unit 1211
Air Mass/Volume Sensor 1215
Throttle Potentiometer 1216
Output Stage, Group 1 1218
Output Stage, Group 2 1219
EGO(O2) Sensor 1 1221
EGO(O2) Sensor 2 1212
Lambda Control 1 1222
Lambda Control 2 1213
Coolant Temp. Sensor 1223
Intake Air Temp. Sensor 1224
Knock Sensor 1 1225
Knock Sensor 2 1226
Knock Sensor 3 1227
Knock Sensor 4 1228
Battery Voltage/DME Main Relay 1231
Throttle Idle Switch 1232
Throttle WOT Switch 1233
Speedometer A Signal 1234
A/C Compressor cut off 1237
A/C Compressor 1242
Crankshaft Pulse Sensor 1243
Camshaft Sensor 1244
Intervention AEGS 1245
Ignition Secondary Monitor 1247
Fuel Injector 1 (or group 1) 1251
Fuel Injector 2 (or group 2) 1252
Fuel Injector 3 1253
Fuel Injector 4 1254
Fuel Injector 5 1255
Fuel Injector 6 1256
Fuel Injector 7 1257
Fuel Injector 8 1258
Fuel Pump Relay Control 1261
Idle Speed Actuator 1262
Purge Valve 1263
EGO Heater 1264
Fault Lamp (check engine) 1265
VANOS 1266
Air Pump Relay Control 1267
Ignition Coil 1 1271
Ignition Coil 2 1272
Ignition Coil 3 1273
Ignition Coil 4 1274
Ignition Coil 5 1275
Ignition Coil 6 1276
Ignition Coil 7 1277
Ignition Coil 8 1278
Control Unit Memory Supply 1281
Fault Code Memory 1282
Fuel Injector Output Stage 1283
Knock Control test Pulse 1286
No Failures 1444
Thats what I could find.
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline
Fault Code Reader?? eric 5-Series (E12,E28, E34, E39, E60) 2 04-14-2005 02:46 PM
Fault Code Reader silverjettin 3-Series (E36) 7 03-04-2005 07:42 PM
Fault Code Reader okczy21 3-Series (E36) 2 10-25-2004 08:44 PM
Fault Code Reader schilke North Central 2 07-22-2004 03:26 PM
