fan and thermostat - BMW Forum - BimmerWerkz.com
Old 09-07-2005, 11:59 AM   #1 (permalink)
sadubaba is on a distinguished road
Question fan and thermostat
Can someone help. I think I have a faulty thermostat, 2nd one in 4 mths on
an e36 2.0i coupe.
When I try to remove the fan coupling the whole engine tries to turn.How can I stop this? Also does the thermostat housing have 3 or 4 bolts holding it in place- as I can't get the fan off i am having problems accessing the housing.
Help would be most appreciated
Cheers
Sadubaba
sadubaba is offline   Reply With Quote
Old 09-07-2005, 01:52 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Well... there is a tool for your problem that BMW makes... or if you look down at the fan shaft... there is a large nut... and then a small nut in which the fan unbolts from the shaft... if you hold the large one still with the tool or a very thing large mm wrench that will hold the shaft in place while you un-bolt the fan.
As for the thermo housing there are three bolts... if I'm not mistaken... two small and one larger on on the top.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 09-09-2005, 01:08 AM   #3 (permalink)
Car: 97 328is, 93 318is
thinair is on a distinguished road
Send a message via ICQ to thinair Send a message via MSN to thinair
The fan clutch nut is reverse threaded. And I use a long screw driver to wedge the one of the 4 bolts on the water pump pulley to keep it from moving. Once the fan clutch and pulley are off, there are 4 bolts holding on the thermostat housing.
Inspect the housing for any signs of cracks before reinstalling it.
Nelson Papel
1997 Madeira Violet 328is - Carbonio Intake, Racing Dynamics exhaust, fan delete, ASC delete, M50 intake manifold, M3 Cams, Eurospeed/AA software, 3.38LSD, M3 f&r brakes + MC, Bilstein PSS, Eibach swaybars, BBS RK 17x8" wheels, Toyo T1R (235/40R17) tires, Racing Dynamics K55 kit, full euro lighting, 4300k HID lows, etc..........
<a href='http://www3.sympatico.ca/thinairbikes/bmw.htm' target='_blank'>Click here for more info on my car</a>
thinair is offline   Reply With Quote
Old 09-09-2005, 10:42 AM   #4 (permalink)
Thanks guys, got the fan off and there are 4 nuts on the stat housing.After doing all this I find the stat is fine, probably the water pump?
Cheers again
expansion tank exploded (literally) cheripie 3-Series (E36) 16 11-08-2005 04:10 PM
