Fan blower is stuck, how do I fix this? - BMW Forum - BimmerWerkz.com
Old 08-09-2004, 10:16 PM   #1 (permalink)
When I turn the fan it sounds like there's something blocking the air from comming in. There's very little air comming through the vents. However, when I turn on the AC and have the air recirculated the air blows full blast. It would seem that when the fan draws air from the outside it gets stuck, possibly a flap? How do I fix this? Microfilter has already been removed.
Thanks,
Bry
Old 08-09-2004, 10:43 PM   #2 (permalink)
Kevin325i's Avatar
See if you can access the little inlet at the base of the windsheld from under the hood. Perhaps something fell in there and is blocking the fresh air flow in. All I know is that my "vent" air is warm as all hell unless it's like 60 degrees outside even with the little dial turned to the blue mark.
Kevin (President TBEA)
Old 08-09-2004, 10:48 PM   #3 (permalink)
I'll check that thanks. I doubt it's the problem though. It sounds like there's a flap stuck somewhere under the dash.
Bry
Old 08-09-2004, 10:56 PM   #4 (permalink)
Kevin325i's Avatar
Isn't there a flap in that inlet? That's the only one I can think of, mostly because it will be fairly simple to get at, everything else seems like a bitch. If I come across a diagram I'll post it up.
P.S. You still got that dinan book with the dyno graphs....
Old 08-09-2004, 11:07 PM   #5 (permalink)
I almost forgot. Sorry about that Kev. I'll get it up right away!
Bry
AC/heater blower fan control problem????? help gsrboy171 3-Series (E21, E30) 13 10-19-2005 08:59 AM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
AC BLOWER STUCK IN LOW 1997BMR 3-Series (E36) 9 07-29-2003 03:24 PM
