Extremely High Idle Wont Come Down - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 03-08-2005, 01:11 AM Thread Starter
BMWjiggaB is an unknown quantity at this point
My car when i start it up will rev straight up to right under the redline at about 6300rpm and will stick there and wont come down at all. Not sure if vacum line or idle air control valve. Its not the tps sensor as i have checked that at work allready. I cant seem to find the idle air control valve to clean it and check it out. I believe its under the intake manifold but cant locate it. Any ideas or experiences with this. I have a 96' 328is.
BMWjiggaB is offline
post #2 of 7 (permalink) Old 03-08-2005, 02:41 AM
thekid's Avatar
thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute
Have you checked the throttle cable? This sounds too bad to be any of the things you listed. See if it has any slack...
thekid is offline
post #3 of 7 (permalink) Old 03-08-2005, 03:42 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
this might sound silly, but you sure your carpet isnt on the throttle? i had the same problem but my idle wastnt that hight, in any event just want to make sure you dont overlook the obvious
Furious is offline
post #4 of 7 (permalink) Old 03-08-2005, 03:46 AM Thread Starter
[snapback]306269[/snapback]
Yes i have checked the throttle cable and it is ok. THe butterfly on the throttle body which opens when u give it gas, via the throttle cable, stays shut when it is reving high like that. Under normal circumstances it should open with the push of the gas.
post #5 of 7 (permalink) Old 03-08-2005, 11:26 AM
thekid's Avatar
hmmm.... this is getting tricky then. I had a vacum leak and a drity idle control valve and I experianced erratic idle rpms, but only between 600 and 1.5k ish rpm... I've never heard of a vacuum leak reving that high. Also the butterfuly being closed and still allowing the rpms to be that high is really strange. hmmm.... I'll keep thinking....
Also I have a 318i so I can't help you with the Idle control valve location. But on mine it is under the manifold on the back side of the engine, but I am not sure on the 6cly models if the placement is the same.
thekid is offline
post #6 of 7 (permalink) Old 03-09-2005, 04:39 AM Thread Starter
Well its another day and i took my intake manifold off and everything around it and found my idle air control valve and i cleaned it up. It was just a little bit dirty but nothing major. So i put it back on, after losing one of my intake screws on the ground in the process, and i put everything back on. Went to start it and it was at 4500rpm and then 2 seconds later it grew again back up to redline. Is there any kind of sensor that if unplugged or something would cause this? I have no clue whatsoever now. I can take it anywhere without the aid of a tow truck or a trailer. Much help appreciated.
post #7 of 7 (permalink) Old 03-09-2005, 06:22 AM
mmclaren is an unknown quantity at this point
unscrew the throttle cable, its the wire thing with a plastic clip on it
mmclaren is offline
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
High Idle yamaha405 3-Series (E21, E30) 7 03-09-2005 09:27 AM
High Idle dfw325e 3-Series (E21, E30) 1 10-18-2004 06:01 PM
