Expansion Tank Leaking - BMW Forum - BimmerWerkz.com
Old 05-13-2005, 06:33 PM   #1 (permalink)
kvadgama is an unknown quantity at this point
My expansion tank is leaking coolent. Can I just replace the tank or do i need to replace the radiator too.
Is it easy to replace the tank only?
Thanks
K
kvadgama is offline   Reply With Quote
Old 05-14-2005, 10:38 PM   #2 (permalink)
green325is's Avatar
green325is is an unknown quantity at this point
You can just replace the tank by itself. Depending on how old your radiator is, consider that too. When you replace your tank don't forget to replace the coolant level sensor, a cheap $20 that let's you know your coolant is low. Very annoying when they stop working, which mine did!
green325is is offline   Reply With Quote
expansion tank exploded (literally) cheripie 3-Series (E36) 16 11-08-2005 04:10 PM
Radiator Leaking Need Help! jroberts312 3-Series (E36) 3 02-08-2005 05:48 PM
Removing Expansion Tank From Rad? ballin 3-Series (E36) 1 11-14-2004 12:27 PM
Help, Coolant tank leaking walt525tour 5-Series (E12,E28, E34, E39, E60) 9 08-26-2004 09:39 PM
1991 320i Leaking fuel tank Grey2000 3-Series (E21, E30) 4 08-07-2004 12:16 PM
