exhuast noise - 1992 325is - BMW Forum - BimmerWerkz.com
Old 05-24-2004, 02:56 PM   #1 (permalink)
IvanB's Avatar
IvanB is an unknown quantity at this point
When i bought the car, it seemed noiser that I remember a stock 325is being,
clearly audible from inside the car with the windows rolled up, esp starting out from a stop.
The stock cat was replaced last month in an effort to get the car smogged(it eventually passed smog, barely) . after replacing the cat the exhaust system was still noisy.
I put my ear near the muffler and it sounded like noise was coming from that area, sooo I bought a new ansa muffler and had that installed today.
guess what... its even louder!
The muffler guy said that whoever installed the cat converter used an aftermarket one and its smaller than the original OEM cat, so he thinks the noise is not being dampened by the cat.
I asked him about a resonator and he said that my car didnt use a resonator and that the noise control came from a combination of the cat and the muffler.
has anyone else had this problem? do I have to use a stock muffler and cat to get the car 'as new' quiet?
I thought that mufflers made things quiet -- has anyone else heard of a cat being used to quiet an exhaust system?
anyhow thanks for the help!
IvanB is offline   Reply With Quote
Old 05-24-2004, 05:18 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
mufflers actually can varry in noise depending on performance of the exhaust, the ansa muffler you got, is it a performance aftermarket upgrade?
Old 05-24-2004, 05:44 PM   #3 (permalink)
IvanB's Avatar
the ansa muffler is considered an OEM "comaptible" muffler. Its not a performance muffler upgrade.
it looks pretty boring, similar to the OEM muffler in size, its just aluminum instead of painted black like the OEM muffler.
Old 05-24-2004, 07:26 PM   #4 (permalink)
MyBimmer3's Avatar
MyBimmer3 is an unknown quantity at this point
Send a message via AIM to MyBimmer3
I think the 92 325 does have a resonator because my '93 325is has one and im sure a 92 does too. what does this sound sound like? is it a raspy noise? vibrating sound? clicking? etc? give me an idea and i think i might be able to help ya help. because the resonator is the one thing you didnt look at yet i would look into that then if that doesnt fix it i would say its not fromt he exhaust, it could be ffromt he engine and is just being projected out the exhaust.
MyBimmer3 is offline   Reply With Quote
Old 05-24-2004, 07:30 PM   #5 (permalink)
MyBimmer3's Avatar
if it is a clicking noise it could be comeing from a stuck or partialy stuck exhaust valve or a exhaust vlave with a broken spring causing it to bounce instead off creating a good seal. there are so many things that create bad nioses and so many types of noises that you really need to describe the noise. in as much setail as possible. IM not an expert ( only 16) but ive learn alot form my dad so i might be able to help adn i can even ask him if i dont know it.
Old 05-26-2004, 12:09 PM   #6 (permalink)
IvanB's Avatar
The stock exhaust sounded like i had put a performance exhaust on, deep, raspy esp. at < 2000 rpm. Which makes it sound like a bucket when your stopping and starting.
At high rpm's the sound you cant really hear it over the freeway noise so its not too bad.
I had both the cat and muffler replaced with compatible new parts and the noise didnt go away, i got a bit worse , the new ansa muffler is raspier.
it interesting you say yours has a resonator, maybe they added one for 93 model year. Does anyone else have a resonator on there 92-99 ?
my guy said i dont!
Old 05-26-2004, 10:30 PM   #7 (permalink)
Kevin325i's Avatar
I don't. And mine is loud as you said, but I like it that way.
Kevin
Kevin (President TBEA)
Old 05-26-2004, 11:33 PM   #8 (permalink)
BMWg84 is an unknown quantity at this point
Send a message via AIM to BMWg84
92s are naturally loud because of the aggressiveness of the exhaust camshaft. We lack Vanos, so our "hot" cams make up for the needed horsepower/torque. I recommend getting an M3 exhaust. ANSA will still give you a loud note because it's very free-flowing. The M3 exhaust is packed with sound absorbing materials and chambers, which will allow for a more subtle sound.
BMW ENTHUSIAST
BMWg84 is offline   Reply With Quote
Old 05-27-2004, 01:15 PM   #9 (permalink)
IvanB's Avatar
thanks Chris, appreciate the suggestions, I saw a m3 exhaust for sale on ebay pretty cheap, from a 96 i think. the bolt pattern looked similar.
Old 05-27-2004, 03:55 PM   #10 (permalink)
greennvmachine is an unknown quantity at this point
Send a message via Yahoo to greennvmachine
it is always possible that you have an exhaust leak as well check your manifold and gasket
greennvmachine is offline   Reply With Quote
Old 05-27-2004, 09:25 PM   #11 (permalink)
Kevin325i's Avatar
'92s represent. We've also got larger valves.
You wouldn't happen to know the specs on both the intake and exaust cams would you?
Kevin
Deep Sound Exhuast For A 325is?? shuiyuan 3-Series (E36) 12 07-05-2006 01:16 PM
1992 325is speaker replacement question danyal711 Audio and Electronics 7 09-08-2004 04:26 AM
1992 325IS engine + tranny swap danyal711 3-Series (E36) 6 08-20-2004 12:57 PM
1992 325is transmission + electronic problems danyal711 3-Series (E36) 1 08-13-2004 10:31 PM
Wanted in July 1992 325is Wurzig-Drei Classifieds Sell & Buy 0 05-20-2004 08:30 PM
