Exhaust Valve!!??!?! - BMW Forum - BimmerWerkz.com
Old 01-01-2005, 05:56 PM   #1 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Slvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
So some of you may know, my brother just bought a 98' 328is. It is super nice and has a really nice sound to the exhaust. But I dont think the sound is stock. So I looked at the exhaust and there is a valve in one of the pipes. (see picture 1 "valve open") When the car is off, in neutral, or the when the revs are really high, it is open. When the car is in gear, and crusing normally, it is closed (see picture 2 "valve closed) Is this thing stock? Bad for HP?
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline   Reply With Quote
Old 01-01-2005, 06:06 PM   #2 (permalink)
xxxbimmer's Avatar
xxxbimmer is an unknown quantity at this point
Send a message via AIM to xxxbimmer
wowsa........any idea as to what kind of exhaust that is
<img src='http://img.photobucket.com/albums/v496/pwr2thenike/asfasdf.jpg' border='0' alt='user posted image' />
xxxbimmer is offline   Reply With Quote
Old 01-01-2005, 06:07 PM   #3 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
To my understanding, it is a stock exhaust
Old 01-01-2005, 06:22 PM   #4 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Im 99.9% sure its stock. I think it had something to do with the california smog laws. But when you give the car full gas it should open so when you need the power it should all be there. Not sure though.
-Serge
theruss1an1 is offline   Reply With Quote
Old 01-01-2005, 06:29 PM   #5 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
thats really weird.
catalyst. is offline   Reply With Quote
Old 01-01-2005, 06:29 PM   #6 (permalink)
-pimpin328is-'s Avatar
-pimpin328is- is an unknown quantity at this point
im 100% sure its stock. i was told that it closes to supress the sound of the exhaust, to make it more quiet when flow isn't important ie idle, cuising speeds. but opens duing full throttle or high revs to allow better flow
Mods: Tint, Euro Tails, Smoked corners and Side Markers, E46 Style Shadow Grill, 18&quot; M3 Replicas, M3 Exhaust, Low Beam Silver Stars
-pimpin328is- is offline   Reply With Quote
Old 01-01-2005, 10:27 PM   #7 (permalink)
Kevin325i's Avatar
It's for more low end torque. Removing it will potentially hurt performance.
Kevin (President TBEA)
Old 01-01-2005, 11:07 PM   #8 (permalink)
Threadkiller
bitcore's Avatar
Word to -pimpin328is- and Kevin325i. Both very correct.
Good for HP. Quiets the exhaust when power is not needed. Helps low end torque with added backpressure.
If you fold down the rear seats, roll up the windows and turn off the air and the radio, listen carefully, you can hear the air pump opening and closing it. It's pneumatic.
That sums up this question. Thread closed.
Old 01-01-2005, 11:18 PM   #9 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
That valve pretty much creates back pressure for your exhaust system... and thus your engine... unless you give your engine more air.. (intake).. and then tell your ECU to use the greater air supply.. and then a more free flowing exhaust ( remove valve maybe or a new performance exhaust) Removing that valve will decrease the back pressure on your engine.. which is needed for low end torque like what was said above...
Les
1997 E36 M3 1990 E30 325i
Old 01-02-2005, 07:12 AM   #10 (permalink)
Super Moderator
dutchbmw's Avatar
I've just read about the new 535 diesel that has some kind of valve too. They say it's for quiet (not sure on what rpm or speed) the car some more.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 01-02-2005, 03:36 PM   #11 (permalink)
Silverstreak is an unknown quantity at this point
[snapback]262520[/snapback]
Right now I have the valve disabled on my 328is and it sounds a lot better but there is a small amount of torque in lower rpms that is lost. I really don't care because if I want to go fast im above 400 rpms+. The valve is closed under 2500 RPM and open above that. It is for noise suppression and backpressure. Now that I have just installed the M50 intake manifold I am going to reconnect it to see if there is a difference with it on... So far it sounds really awesome with burbley lil pops like a rally car lol.
If you are wondering how to disable it and have it open all the time for a deeper bass'ier sound just look under your car and unplug the vacuum line that goes into the exhaust, then plug it up with something like a golf tee.
Finally open the trunk, lift the carpet up and at the bottom left you can see the vacuum line. Pull an inch or two of it up so the vacuum line is not hanging down near the ground. This can easily be reversed in 1 minute and make your esxhaust louder and deeper sounding
<a href='http://www.cardomain.com/memberpage/237652' target='_blank'><img src='http://img170.exs.cx/img170/5774/sig2uq.jpg' border='0' alt='user posted image' /></a>
Mods: M50 intake manifold, BFP CAI, Fan delete, CDV delete, Clears all around, M contours, Clutch stop, Debaffled exhaust, CF BMW emblems
Silverstreak is offline   Reply With Quote
Old 01-03-2005, 02:07 AM   #12 (permalink)
robbins6103's Avatar
robbins6103 is an unknown quantity at this point
Send a message via AIM to robbins6103
stock
<img src='http://memimage.cardomain.net/member_images/8/web/740000-740999/740645_1_full.jpg' border='0' alt='user posted image' />
robbins6103 is offline   Reply With Quote
Old 01-03-2005, 02:42 AM   #13 (permalink)
Team Perfect Line's Avatar
Team Perfect Line is an unknown quantity at this point
Stock indeed. For "low end torque" and being quiet. Quite a god piece of technology actually.
Perfect Line
Team <span style='color:blue'>Perfect Line</span>
<span style='color:blue'>e46 M3 | e36 328i | e36 M3 | 04 Mini Cooper S | s14 240sx | FD RX-7 | 93 mr2t | 03 G35C | 04 RSX | 03 RSX | 2.2L s2000 | 05 Evo MR</span>
<img src='http://server2.uploadit.org/files/MpowerBMW-TPLsig.jpg' border='0' alt='user posted image' />
Team Perfect Line is offline   Reply With Quote
Need Help!1987 325es: Exhaust Leak/runscrappy pettas 3-Series (E21, E30) 12 12-11-2004 05:12 AM
If Your Looking For A New Exhaust For A 328i... RDM3 Classifieds Sell & Buy 0 11-23-2004 04:07 PM
Fs Fk Automotive Exhaust For E36 328i New RDM3 Classifieds Sell & Buy 0 11-23-2004 04:06 PM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
