Euro MAF conversion - BMW Forum - BimmerWerkz.com
Old 05-23-2009, 04:29 AM   #1 (permalink)
Tr1cky's Avatar
Car: 1996 328i coupe.
Tr1cky is on a distinguished road
Send a message via ICQ to Tr1cky
Euro MAF conversion
I have a 328i coupe.
Have done the M50 Manifold conversion, works well.
Have removed the traction control and replaced with a samco elbow from Bimmer world, very nice.
Have lost the standard airbox and replaced with COSMOS racing 3.5" cold air intake. works well
and have fitted M3 extractors and 24lb injectors.
Had a dyno tune and am making 135kw at the rear wheels.
thats the good bit
the problem is i have fitted a 3.5" Bosch MAF, in place if the 3" Siemes MAF.
After modifying the socket on the MAF the standard plug fits.
But i continue to get MAF erros on the DME when i check with code reader.
I am worried that the ECU wont be working properly if the MAF is not functioning correctly.
Has anyone sucessfuly done a euro MAF swap?
i would like to know what i can do to ensure im running 14.7 AFR
thanks
Tr1cky is offline   Reply With Quote
Old 05-23-2009, 09:24 AM   #2 (permalink)
My first thought is there's a basic compatibility issue with the MAF and ECU.
Old 05-24-2009, 01:02 AM   #3 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
you know to Use the 3.5 MAF you have to get different software right? Or else you'll get all kinds of errors.......
1992 318i Coupe parts car
I am Captain Obvious
Old 05-25-2009, 06:07 AM   #4 (permalink)
Tr1cky's Avatar
I am thinking the "basic combatability issue between the MAF and the ECU " is my problem.
I have had the ECU totally remapped on a dyno, so dont think its a software issue.
The real question is can you use a Bosch MAF with a siemens ecu?
i can swap the wires around if need be, if the signal could be accepted by the ecu.
Too much power????
Old 05-25-2009, 06:10 AM   #5 (permalink)
Tr1cky's Avatar
actually...
Does anyone know of any 3.5" MAF that can run on a siemens ECU?
Too much power????
Old 05-25-2009, 07:42 AM   #6 (permalink)
Montizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of light
You have to get new software.
99 Dakar M3
|Conforti|Sharked|TC Kline SA|DEPO||BBS|M50 MANIFOLD|UUC|DDM|SPARCO|OEM X BRACE||SSK|ECS TUNING|MISHIMOTO|
Montizzle is offline   Reply With Quote
Maf Question keepiteuro 3-Series (E21, E30) 0 06-15-2005 01:40 AM
Hid Conversion In Euro Ellipsoid Help dopeyx27 3-Series (E36) 5 04-12-2005 12:14 AM
Maf Sensor -pimpin328is- 3-Series (E36) 6 11-14-2004 01:57 AM
Euro Headlight conversion tico481 3-Series (E36) 16 07-11-2004 06:56 PM
MAF conversion? 1985bmw325e 3-Series (E21, E30) 7 03-10-2004 10:57 PM
