Hi everyone this is my first time posting anything on-line, I've got a 1995 316i bmw the key was just spinning and would ever so often catch to allow the car to start, I decided that I had enough so I took the barrel out, taped the key to the ring and was using a screw driver to start the car.It worked for a few weeks, then one day I switched off the car went back to start and nothing happen, so I turn the ignition on then went under the car hook up my remote starter and the engine turn over but would not start then I check for sparks from plugs there was no sparks.now I got a new key with barrel and ring but still not turning over or starting, can anyone tell me what to do? thank you all for your help.
