Engine Transplant - BMW Forum - BimmerWerkz.com
Old 06-29-2005, 04:54 AM   #1 (permalink)
illwasteyou's Avatar
illwasteyou is an unknown quantity at this point
Send a message via MSN to illwasteyou
1992 M50 series 2.5 litre with transmission.
would it fit?
how much would it cost me?
good idea/bad idea?
any thoughts on this?
cheers chaps
<img src='http://img.photobucket.com/albums/v335/illwasteyou/si3.jpg' border='0' alt='user posted image' />
illwasteyou is offline   Reply With Quote
Old 06-29-2005, 09:19 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
fit? ..yes, cost a bit because you gotta change a whole lot, do a search on engine swaps youll see what youll need.
good idea? yes
thoughts? save up
Old 06-30-2005, 12:22 AM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
I'm confused on what you're going to do... go from the 1.8 to a 2.5? First off, don't get a 92 as it's the non-vanos engine and lacks in pure power compared to a functioning vanos m50 engine. Second, you're going to need to have custom engine mounts fabricated which isn't a big deal for someone who knows what they're doing. Third you're going to need EVERYTHING for the engine right down to the wiring harness and MAF. Fourth you're going to probably want a new rear end as well as transmission, brakes and suspension because this engine obvioulsy has MORE power and is 200-300lbs heavier then the 1.8.
Good idea? I would say NO because all of this and labor might cost as much as a decent used 6cylinder BMW.
Thoughts? Get rid of those god damn one piece headlights, turn your car back into stock, sell it and buy a 6cylinder. I see you're from New Zealand, so I'm not sure about the econmic's over there, but what you want to do would probably be cheaper and BETTER if you just bought a whole new car.
jrhaile is offline   Reply With Quote
Old 06-30-2005, 02:03 AM   #4 (permalink)
shot churr
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
Engine Transplant SpeedInfusion 3-Series (E36) 5 12-10-2003 05:55 AM
