Sounds like an M54 engine... Does it come with the DME, and other electronics?
I'm pretty sure that you would have to fabricate some mounting brackets for the transmission and engine.
To answer your question:
| Can this be swapet into my 94 325i without to many problems |
What is your definition of many problems? For one the gauge panel would probably be incompatible with the DME, there are a lot of electronics involved in the e46 along with checks double checks and triple checks. The slightest foul up will cause a check engine light (good luck with getting a smog check). Not to mention you are talking about converting an OBD I to an OBD II car. Like they say with the right amount of money you can do anything (at least that's what I say). You will probably spend 3 times as much money putting an OBD 2 engine and electronics system in there.
To answer your question yes you WILL have problems.... For the price of the electronic systems that you would have to add you might as well buy an E46.
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
