engine swap 318ic to m3 - BMW Forum - BimmerWerkz.com
Old 07-16-2004, 01:21 AM   #1 (permalink)
phenom is an unknown quantity at this point
Send a message via MSN to phenom
I just completed my 95 e36 318 ic M42 engine to the M3 M50 engine. I had a cheap 60K M50 available complete with engine, tranny, drive shaft, differential, subframe, controll arms, wirering harness, ... Only one problem the instrument cluster was reprogammed (according to my mechanic-I don't know what tha really means). At idle it reads 1200 rpm, however when checked with the diagnostic computer the idel is under 800rpm any ideas what the problem is or how to fix it ?
phenom is offline   Reply With Quote
Old 07-16-2004, 01:40 AM   #2 (permalink)
BMWL2's Avatar
BMWL2 is an unknown quantity at this point
Send a message via AIM to BMWL2
I would guess you may need the m3 gauge cluster installed also. When I put a sr20det into a 240sx I had to swap in a newer cluster to work with the ecu. If you have that option I would give it a try.
Motovated Motorsport Forums
http://www.motovatedcc.com
BMWL2 is offline   Reply With Quote
Old 07-16-2004, 01:41 AM   #3 (permalink)
BMWL2's Avatar
also just noticed you went from a 4cyl to a 6cyl I would almost bet that the cluster is the problem(going off of my experiences)
Old 07-16-2004, 11:43 AM   #4 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
Hey! You must have put that SR into an 89-90 model s13 then. I was considering that swap myself, but decided to shine the whole thing and get my BMW.
How long ago did you do the swap?
kestrel325is is offline   Reply With Quote
Old 07-16-2004, 11:57 AM   #5 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
sr20det
sick engine...Rice is good for something
That problem would most likely be the gauge cluster...for one the 4cyl only go up to 140mph on the dial and the M's and higher 6cyl go to 160mph. Calibration is obviously going to be different with different engiens and different computers.
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 07-16-2004, 12:55 PM   #6 (permalink)
ChahalzBMR is an unknown quantity at this point
It's your cluster for sure!!!! You HAVE to change the 318i cluster to the m3 in order to get proper readings. It can not be re-programmed. He lied! He just left it there and did not bother to replace it.
<img src='http://img43.exs.cx/img43/275/Resize.jpg' border='0' alt='user posted image' />
Body: 318i 4 door
Mods: M50 engine, Jim C chip, light-weight flywheel, dual cat-back custom exhaust, 3:15 lsd, euro headlights w/angel eyes, 5300K HID, smoked corner lights, FK Motorsports foglights (crystal clear), ABS plastic upper eyebrow, clear side markers, M3 powered side mirrors w/LED, blacked out grill, M3 lighted shift knob, 17&quot; ROH Furry wheels w/Kumho tires, Brembo cross drilled rotors and Hawk performance brake pads all around, PSS9 Bilstein and H&amp;R coil over kit, front strut bar and Alpine alarm.
ChahalzBMR is offline   Reply With Quote
Old 07-16-2004, 06:31 PM   #7 (permalink)
Thanks everybody we borrowed a m3 cluster and it works. I think the dial is actually calibrated different the spacing on the rmp dial is closer then on the 318. Incidently, the mph dial on my 318ic goes up to 160 not 140.
Old 07-16-2004, 06:33 PM   #8 (permalink)
P.S. I'm going to try to install a M3 colored dial face from bavarian autosport first before I install a new cluster (cluster is $450).
Old 07-16-2004, 08:47 PM   #9 (permalink)
BlantonG13's Avatar
Interesting...I guess convertibles have different clusters than th other 318s
1996 318i
5 Speed Manual
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Old 07-16-2004, 09:42 PM   #10 (permalink)
t0pk0w is an unknown quantity at this point
i thought the m3 motor was an s50??? just wondering....
t0pk0w is offline   Reply With Quote
Old 07-17-2004, 10:24 AM   #11 (permalink)
It's the M3 motor. I may be wrong on this but I think in the US we got a beefed up M50 motor for the M3 while everyone else got the S50 with more power.
What parts needed besides engine for swap a224932 3-Series (E36) 5 09-06-2004 12:06 PM
1992 325IS engine + tranny swap danyal711 3-Series (E36) 6 08-20-2004 12:57 PM
Swapping a '94 318ic engine for a '95 m3 engine a224932 3-Series (E36) 1 07-28-2004 04:14 PM
engine swap, out with old 325i in with younger 325 OldBMR1 3-Series (E21, E30) 6 07-19-2004 07:08 AM
