Engine Shaking - BMW Forum - BimmerWerkz.com
Old 06-23-2004, 09:40 PM   #1 (permalink)
rhyk325i is an unknown quantity at this point
Arrow
I have 1994 325i, now I feel the engine a little bit shaking when idle even after a long run, what should the procedures I should follow to inspect?
I replaced all new six spark plugs(Bosch super 2+) 2 weeks ago, beginning run was OK, but now??? ghead
Thanks for your help :wink
rhyk325i is offline   Reply With Quote
Old 06-23-2004, 09:48 PM   #2 (permalink)
Car: 2008 128i
have you checked the engine mounts?
2008 128i Jetblack
Old 06-23-2004, 09:58 PM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
so is your car idling crappy or what is shaking? I'm kind of confused..
If it's idling like shit, change your o2 sensors and clean your iac or icv.
jrhaile is offline   Reply With Quote
Old 06-23-2004, 10:53 PM   #4 (permalink)
Rev the engine to redline and see if there is noticeably more vibration. If there is, it's probably the engine mounts.
Bry
Old 06-23-2004, 11:10 PM   #5 (permalink)
It should be idling crappy. Is it possible one of the new spark plus die that making crappy?
How should I clean the icv, where is it,
Thanks a lot.
Old 06-24-2004, 12:25 AM   #6 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
it's under the manifold intake. I'm going to be replacing mine next weekend so I'll take pics and how to's then.
Old 06-24-2004, 01:29 AM   #7 (permalink)
Hey man.
you're the great one.....thanks a lot
Old 06-24-2004, 09:38 AM   #8 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
possible that the engine could be misfiring due to a plug error of some sort. Double check those. Engine mounts are definitely a possibility. My girlfriend has a 2000 Pontiac Bonneville SLE, HUGE car, lot of power. Her car was shaking during idle. She went to have it checked out and she had completely broken an engine mount from the chassis...
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 06-24-2004, 01:49 PM   #9 (permalink)
Super Moderator
dutchbmw's Avatar
There's even the possibility to read out some fault codes from the engine. This can help you with it: http://www.peakeresearch.com/products.htm or http://www.pelicanparts.com/bmw/techarticl...ode_Reading.htm
Pieter
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 06-25-2004, 02:59 PM   #10 (permalink)
JT325is is an unknown quantity at this point
dude check your radiator fan......... if you drive like a prick like me then you may have lost a few blades. I have had my car 6 months now and have had to replace 3 fans! since it spins like a prop the engine will shake like a mother if its missing a blade or two.
JT325is is offline   Reply With Quote
Old 06-25-2004, 09:46 PM   #11 (permalink)
Ferrahs's Avatar
Ferrahs is an unknown quantity at this point
How many miles are on the engine because i had a similar problem with my '93 and supposedly it was fixed in '94 but i had to change my engine coils to get rid of the shaking...actually if it gets worse then that is probably what it is.
Ferrahs is offline   Reply With Quote
Old 06-25-2004, 10:20 PM   #12 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Ok for obvious reasons... I'd say look at your motor mounts... atleast check and make sure they are all there... god forbid your missin one...
Next... I could talk for hours on the right type of spark plugs for a BMW....for one... its a distributerless ignition... which fires both ways.... best method for spark plugs... get what the darn manual say to get... NJKs are good stuff... that could be your problem... take a few of them out and see what they look like...
If you have a check engine light on... a fault code reader is always a good investment.... and if you plane to do more mods to this car... its a plus.... good luck with your motor...
1997 E36 M3 1990 E30 325i
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
