Engine RPM Cycles Up and Down Under Load - BMW Forum - BimmerWerkz.com
Old 02-19-2010, 11:08 AM   #1 (permalink)
Car: 1995 325i Conv and 2001 323i Conv
chachaE36 is on a distinguished road
I have a 95 325i Convertible with 91,000 miles. When driving under load the engine RPM cycles up and down about 2000 RPM. With very light throttle applied engine speed is constant and slowly increase with speed. Behaves like this at all speeds, hot or cold engine. This started all of a sudden about a month ago (didn't gradually get worse). No repairs have been attempted yet - any chance there is an easy fix to this?
chachaE36 is offline   Reply With Quote
Old 02-19-2010, 11:26 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sounds like the MAF/AFM to me, you can try giving it a clean with carb cleaner, or you may have a vacuumm leak check your intake hose for cracks or splits, but I reckon its the MAF/AFM playing up, unplug it and see what happens.....
#1 MAF and #3 intake hose, here:
http://www.realoem.com/bmw/showparts...=13&fg=15&hl=1
Ps. welcome to the mad house!!
Old 02-20-2010, 03:33 PM   #3 (permalink)
OK, I pulled the MAF and cleaned it very thoroughly following the example in this YouTube link:
The problem is 95% improved but I can still feel a very subtle surging of the engine when accelerating. I am going to drive it like this for a week and then clean it again. Thanks for the help
Old 02-20-2010, 03:57 PM   #4 (permalink)
Very cool!
Old 02-20-2010, 07:02 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Did that fix it? Sounds like it was probably dirty. There are not many more things that can cause the same problem.
Les
1997 E36 M3 1990 E30 325i
Old 02-21-2010, 04:12 AM   #6 (permalink)
marti5's Avatar
If it keeps doing it after another clean it probably needs a AFM replacement.
Old 02-21-2010, 12:02 PM   #7 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
1995... that's a 15 yr old car.
It's already been mentioned by marti, but carefully check the intake boot for cracks and leaks. bimmers of the 90's are notorious for these
Old 03-04-2010, 05:50 PM   #8 (permalink)
OK, I've cleaned the MAF 3 times and the problem is still there. Also, I borrowed a MAF from a friends car and mine drives the same. I looked carefully at the intake boot and there do not appear to be any cracks. Next, I guess I am going to change the intake hose and see if that fixes it. If anyone has any other suggestions let me know. Thanks
530i Strange Noise at 1500 rpm under load espejo 5-Series (E12,E28, E34, E39, E60) 11 12-20-2009 07:31 AM
engine cut out at 3800 rpm lleerrooyy New Members Check In 2 04-10-2009 08:18 PM
Engine revs up to 2500 RPM with a/c on snpower 3-Series (E21, E30) 11 09-25-2007 04:01 PM
Engine RPM 528iTdude 5-Series (E12,E28, E34, E39, E60) 6 04-08-2007 07:55 PM
Engine Rough at Low RPM CosmosBlack 5-Series (E12,E28, E34, E39, E60) 1 08-30-2003 04:43 PM
