Engine Rattle - BMW Forum - BimmerWerkz.com
Old 07-01-2004, 07:46 AM   #1 (permalink)
timparky is an unknown quantity at this point
I have an E36 1995 M3 3 litre. It has a very strange intermitant dry sounding clatter that appears to be coming from the front of the engine. It has been to 2 BMW dealers who have changed the alternator belt tensioner and the waterpump which has not solved the problem. Now they want to take the head off to investigate which will be very expensive at £84 per hour.
Has anybody had a simular noise or has any suggestions.
Thanks
All responses appreciated.
Tim Parkinson
timparky is offline   Reply With Quote
Old 07-01-2004, 01:08 PM   #2 (permalink)
Kevin325i's Avatar
It could be a sticky lifter that isn't pumping up and closing the clearance between the rocker arm so there's a ticking.
It's hard to diagnose engine noises when you've got so little to go on and it's over the internet. Does it go away after some driving, or does it start making noise after you drive?
Kevin
Kevin (President TBEA)
Old 07-01-2004, 01:13 PM   #3 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
I have a noise that sounds like a metallic rattle, happens loudest around 2k rpms...people have suggested things, but I have no clue what the hell it could be...I know its not exhaust...It sounds almost like a bunch of loose change rattling on something vibrating really fast (if that makes sense)
look out dealer here I come... ghead
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 07-02-2004, 03:37 AM   #4 (permalink)
Kevin
Hello Kevin,
Thanks for the reply. Initially it did go away after imidiate start up them come back when it had warmed up. Now it seems to be there all the time but not so prominant until it gets warm. Your right its hard to diagnose engine noise over the internet, its also quite hard to discribe. The noise is sound like click, click then its silent for a few seconds then click, click, click then silent for a few seconds then click and so on. It does seem to be getting worse though.
When you are driving you can hear it at low revs, when you accelerate it sound a bit like pinking.
However the engine does seem to run a bit smoother after the new waterpump.
Thanks
Tim
Old 07-02-2004, 05:37 AM   #5 (permalink)
Mr White G's Avatar
Mr White G is an unknown quantity at this point
Vanos chain?
<span style='color:blue'>&quot;So my BM makes me a flash bastard? Then I guess you're just keeping it real from the seat of your nova?&quot;</span>
<span style='color:gray'>&quot;...and the home of the brave..... is bravey 130bhp from a 7 litre engine? 100bhp/litre or don't bother building it!&quot;</span>
<span style='color:red'>&quot;Aaahh the UK; where every road is jammed, under construction, poorly maintained and unfairly policed, at least we don't get over-taxed for it........ HA HA HA!&quot;</span>
Mr White G is offline   Reply With Quote
Old 07-02-2004, 12:50 PM   #6 (permalink)
Kevin325i's Avatar
Does it sound like it's coming from the floor of the pasenger side? I've got a click that I'm fairly sure is the wheel bearing, it comes and goes every now and then and the faster you go the faster it clicks.
Your's sounds like (if it's coming from the engine) just noise from the valve train. What type of oil are you using?
Kevin
Old 07-02-2004, 05:30 PM   #7 (permalink)
EuroBeem's Avatar
EuroBeem is an unknown quantity at this point
I would change all the belts from your engine. I had a squeaking noise when i first bought my car and found out that a couple of the belts wit ripped/scratcheda little, so after replacing them the noise went away.
Could be your belts but again like kevin said i cant really tell over the internet.
EuroBeem is offline   Reply With Quote
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
'02 318 Idle / 1500rpm Engine Rattle matrhos 3-Series (E46, E90) 3 09-03-2005 09:32 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
