Engine power loss above 4000 rpm. - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 05-30-2008, 08:18 AM Thread Starter
design engnr is on a distinguished road
HI all,
I have a '97 e36 328i. I had some issue with the car not starting about a week ago. I was able to open the butterfly up slightly and get it to where it would idle. I have not hada chance to dig into it further since doing that, and truly fix the problem. Then yesterday on my commute home from work i noticed that as I accelerated in any gear the engine would bog severely above 400 to 4500 rpm. I have searched all over the net trying to diagnose the problem, but can't find anyone with my issue. Could the two issues described above be related? I need to check my ICV, and MAF sensor, but I am not sure if these could create the condition I am getting. Any help would be much appreciated.
Thanks,
Dave
design engnr is offline
post #2 of 8 (permalink) Old 05-30-2008, 09:05 AM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
Originally Posted by design engnr View Post
HI all,
Thanks,
Dave
Hi! Dave! Is your check engine light on? Also I think a defective MAF can cause those conditions!
johnny,
____________________________________________
johnnyBgood is offline
post #3 of 8 (permalink) Old 05-30-2008, 09:38 AM
bimmerguy82's Avatar
bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute
maybe a weak fuel pump?
BMWcrazy
___________
-Joshua
BMWCCA member#407674
bimmerguy82 is offline
post #4 of 8 (permalink) Old 05-30-2008, 11:10 AM Thread Starter
Thanks guys,
The car isn't throwing the Check engine light. Is there any good way to test the MAF and fuel pump?
Dave
post #5 of 8 (permalink) Old 06-01-2008, 11:19 AM
darkhorse737's Avatar
Quoted: 2 Post(s)
Lightbulb
fuel pump is tested by a pressure test vis-a vis the volume of output per given time. MAF/AFM can be tested using an ohmeter and visual inspection - but may i suggest that you take your car to a shop that can do a scan on it. It's the logical way to fix probs fitted with OBD2. The data printout will tell u a world of things, and take out all the guesswork.
Offhand, if you are losing power above 4000rpm, what immediately comes to my mind is o2 sensor gone wacky; ignition timing malfunction(spark advance in particular)... or the rev limiter cut-off switch wrongly adjusted/gone bad.
darkhorse737 is offline
post #6 of 8 (permalink) Old 06-02-2008, 05:29 PM
ayyado's Avatar
ayyado is an unknown quantity at this point
Could be spark plugs??
<img src='
ayyado is offline
post #7 of 8 (permalink) Old 06-05-2008, 12:16 AM
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
i had something similar happen to me in e30. check for engine seal leaks. perhaps timing chain, ignition timing malfunction. does transmission respond out of sync in anyway during shifting? I had car serviced, problem never came back up. but was no explanation other than typical service new timing belt, and v belts. oil change.
pinnaclebass is offline
post #8 of 8 (permalink) Old 06-07-2008, 11:24 PM
Bimmer M.D.'s Avatar
Bimmer M.D. is on a distinguished road
Have you tried the pedal trick? You can check for error codes even if the check engine light is not on by doing the pedal trick. Chances are if there is a problem, it threw a code and will show up.
** FOR SALE NOW! ** 1 Day Left! ** Click Picture! **
Bimmer M.D. is offline
power loss! bimmerguy82 3-Series (E36) 7 02-28-2007 12:59 AM
Loss of power between 2-3k rpm sinnes 3-Series (E46, E90) 0 07-06-2004 08:50 AM
318i lacks power over 4000 rpm mattg 3-Series (E36) 4 05-21-2004 04:49 PM
Power Loss BlackEye 5-Series (E12,E28, E34, E39, E60) 6 08-21-2003 04:28 PM
