Engine pinging is drivin me nuts! - BMW Forum - BimmerWerkz.com
Old 06-21-2004, 09:22 PM   #1 (permalink)
DCrew is an unknown quantity at this point
The pinging from my '93 325i has gotten so bad it's starting to sound like a 240D. No chip, Amoco Gold, 64K miles. Moderate acceleration in any gear, even pulling away from a stop. I understand this isn't uncommon with these motors...what is the cure? Thanks everyone from a NEW member...
Dave
DCrew is offline   Reply With Quote
Old 06-21-2004, 10:07 PM   #2 (permalink)
dport's Avatar
dport is an unknown quantity at this point
I believe the cars have a knock sensor to prevent that. You might get that checked out. Is Amoco gold 87 or 89 octane? It is not unusual for older cars to want more octane. Is your tune up current?
<img src='http://img.photobucket.com/albums/v417/dport135/newsig.jpg' border='0' alt='user posted image' />
'95 318i Brembo Sport Rotors, B &amp; G Springs, Tokico Shocks/Struts
dport is offline   Reply With Quote
Old 06-21-2004, 10:37 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
yeah sounds like the knock sensor is out or something, that or the gas is not up to par. i run 91-94 octane and with a chip to boot, no pinging for me.
lastly try some fuel treatment, and see if it helps.
(i like using the one from lucas)
Old 06-22-2004, 12:06 PM   #4 (permalink)
Amoco Gold is 92 octane. I had an inspection II done about three months ago, so the plugs, etc are all new.
I'm told that if the knock sensors are bad it will leave a fault code on the OBD, and will also make the engine light come on. Neither has happened. If there's an expert on knock sensors please tell me if this is correct and if they could be the problem. They're darned expensive to change without being sure.
Thanks again,
Dave
Old 06-22-2004, 01:45 PM   #5 (permalink)
Silver4evr's Avatar
Are you losing aceleration?
What does the dealer say?
Have the tech go with you on a test ride.
They should be able to figure it out. That's their job. If they can't, find another mechanic.
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
