engine misfiring! coil packs? 1998 318i - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 03-28-2013, 06:20 PM Thread Starter
BIMMER3SERIES303 is on a distinguished road
cylinders misfiring in every gear.( can barely drive it) this all happened in one day! valve cover has been leaking oil into most spark plugs for a bit. sounds like i need new plugs, coil pack,gasket,wires!!! Is this a hard fix on a 1998 bmw 318i???
BIMMER3SERIES303 is offline
post #2 of 2 (permalink) Old 03-30-2013, 09:44 AM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
I just saw your other post regarding the spark plug wires. First, you should get the On Board Diagnostic (OBD) system scanned for Trouble Codes (DTC) to determine which cylinders are missfiring. The Code will start with P03xx if their is a misfire. The last two digits (represented as xx) will be which cylinder is misfiring.
What you want to to is swap the coil pack from the cylinder that is misfiring with one that is not. If this misfire follows the coil pack, then you know the coil pack has gone bad and needs replacement. With spark plugs, BMW engines are pretty picky about what plugs they use. I personally prefer NKG plus, and use the BRK6EK plugs in my M52.
The oil leaking into the plug wells is from the Valve Cover Gasket (VCG). Its a rubber gasket, and over time turns hard and brittle from the heat of the engine. This is quite common. I have replacement my VCG because of this before.
Replacing the VCG and plugs/wires/coilpacks at the same time will save on labour costs as the old ones will all need to be removed to replace the VCG.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
1998 318I WindShield Wipers tjgilbert81 Picture Showroom 0 03-13-2013 10:51 PM
1998 328i misfiring!!!!! 325isBMW1988 3-Series (E36) 7 08-18-2010 07:04 PM
High Performance coil packs? bimmerguy82 3-Series (E36) 6 05-24-2008 02:59 AM
Rear Coil Measurement 318i singring 3-Series (E36) 2 07-27-2006 07:52 PM
Bad Ignition Coil or ECM? 93 318i kylejsutin 3-Series (E36) 4 08-09-2004 09:15 PM
