Engine cooling fan question - BMW Forum - BimmerWerkz.com
Old 09-27-2003, 09:34 AM   #1 (permalink)
325iS's Avatar
325iS is an unknown quantity at this point
Thumbs up
I'm refering to the engine cooling fan driven by the water pump -- not the electric cooling fan.
I have worked on and modified Mustangs for the past 9 years and I know that the cooling fan has a clutch that will allow it to disengage at higher RPM range. When the engine is shut off, you can do a quick check of the fan clutch by manually rotate the blades by hand and the clutch should have a slight resistence (i.e. the fan should not remain moving after you spin it hard).
While under my hood of my 325iS the other day, I tried to rotate the fan and it would not bugdge. I'm curious if the M50 fan should operate the same way as my Ford.
-Brian
-Brian-
'88 Mustang LX coupe
- - - 11.56 @ 120 - - - 410 rwhp / 459 rwtq (Naturally Aspirated)
Hell yeah, it's a street car!
'92 325iS - - - - - - - - - 15.328 @ 89.70
325iS is offline   Reply With Quote
Old 09-29-2003, 09:06 AM   #2 (permalink)
325iS's Avatar
ttt
This is a pretty simple question -- I figured I'd have an answer by now.
-Brian-
Old 09-29-2003, 10:15 AM   #3 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
Well its pretty logical answer if you just follow the thought process. Now Im not sure if this is the answer but im just deducting from what you told.
1. The fan clutch disengages at high speeds.
2. When the car is off you cannot budge the fan.
3. answer. Your clutch is good because by spinning the fan you are trying to rotate the entire engine, crank and all. If your car is in gear this aint gonna happen.
Fox is offline   Reply With Quote
Old 09-29-2003, 11:17 AM   #4 (permalink)
325iS's Avatar
The fan clutches that I have been familiar with use a fluid-based clutch system that will allow you to rotate them while at rest with some resistance. Even at low RPM, the fan is never fully engaged to the water pump. However, at higher RPM the clutch fully disengages and allows the fan to completely freewheel.
Thank you and I appreciate the attempt at answering my question.
If anyone has an M50 engine, take a few minutes and do this test for me. Lift your hood and locate the engine cooling fan (the one that is mounted to the water pump). With the engine off, try to rotate the fan blades by hand. Does it spin or will it not budge?
-Brian-
Old 10-01-2003, 03:56 PM   #5 (permalink)
wjwbmw is an unknown quantity at this point
Mine spins freely as it should when the engine is off. If yours doesnt something is wrong. Time to do the fan delete mod.
wjwbmw is offline   Reply With Quote
Old 10-01-2003, 04:11 PM   #6 (permalink)
325iS's Avatar
Thank you so much. I was beginning to wonder if I was going to get a response. :nice:
-Brian-
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
HELP! - Engine/Tranny Vibration & Engine Light Fangs 3-Series (E46, E90) 10 01-24-2004 07:30 PM
Question about the check engine light. jdwango 3-Series (E36) 4 10-10-2003 10:51 AM
Question About 330i Battery sbrenner 3-Series (E46, E90) 2 09-26-2003 12:38 AM
