Engine Clicking - BMW Forum - BimmerWerkz.com
Old 12-28-2004, 12:58 PM   #1 (permalink)
350z
Car: 03 Nissan 350z Track
hey guys do you any of you know why my engine might be clicking when im sitting still and i rev my engine, it revs up fine etc, but you can hear a click click click all the wayup... my friend thought i needed more oil (checked its perfeectly between the two lines, and he also thought maybe my injectors were dirty and making this noise, and told me to go buy injector cleaner. Can either of these two thiings help the clicking noise? also does anyone know what im talking about and have heard it before
David
**BAKER POW REPORT**
Old 12-28-2004, 01:56 PM   #2 (permalink)
93 325i's Avatar
Yea my car does it for a few secs during a cold start. Which is oil related obviously. In your case since it seems to be lasting even when warm it is probably the noisy lifter issue that was common on 92's. I would try the injector cleaner and go from there.
Complete mod list and pics:
My 1993 325i
Old 12-28-2004, 02:32 PM   #3 (permalink)
350z
yeah my friend said something about lifters... so injector cleaner can probably take care of the lifter problem? what exactly is the lifter? and if they cleaner doesnt do it, what else could it be>?
David
Old 12-28-2004, 03:49 PM   #4 (permalink)
93 325i's Avatar
The M50 engine is prone to have noisy lifters. If it isnt effecting performance then I owuldn't stress over it. I have heard of people putting in a little bit of ATF (because it's high dettergent) in the crankcase for 1000 miles then doing an oil change. BUT I wouldn't recommend it because along with cleaning the lifters it attacks the seals and you may get oil leaks. If you cant clean them then you have to replace them.. IF your car seems to be lagging and sluggish then it may be a cam tensioner or cam realted somehow...
My 1993 325i
Old 12-28-2004, 04:46 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Check your oil level... it might be a little low... if its low.. this is the first sign... fill her up.. and it should quiet her down a bit...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 12-28-2004, 06:17 PM   #6 (permalink)
grtmoby is an unknown quantity at this point
This is the sound coming from the hydraulic tappets and this should be gone when the car is at operating temperature. If you always has this sound so then they are defective. unfortunately, they can't be fixed, only replaced.
grtmoby is offline   Reply With Quote
Old 12-29-2004, 05:18 AM   #7 (permalink)
metalmayhem's Avatar
metalmayhem is an unknown quantity at this point
Send a message via AIM to metalmayhem
Originally posted by bigred318@Dec 28 2004, 02:32 PM
yeah my friend said something about lifters... so injector cleaner can probably take care of the lifter problem?* what exactly is the lifter? and if they cleaner doesnt do it, what else could it be>?
David
[snapback]259721[/snapback]
Lifters ride the camshaft lobes to control the opening and closing of the intake and exhaust valves. Also try using a genuine BMW oil filter. Aftermarket filters do not supply enough oil to the head. They concentrate more on filtration as most large motors have lower pressure oil pumps!
metalmayhem is offline   Reply With Quote
Old 12-29-2004, 12:12 PM   #8 (permalink)
350z
okay guys i will try all of this thanks for all the help! it was great! my oil is half way between the first and second line isnt that where it is supposed to be?
David
Old 12-29-2004, 09:01 PM   #9 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
yep. my 300zx used to do the exact same thing. i know its not a bmw, but it was the lifters causing the clicking noise. exept my car would make more a "tink" noise for some reason.
abemcclellan is offline   Reply With Quote
Old 12-30-2004, 12:54 AM   #10 (permalink)
Black318IS is an unknown quantity at this point
It could also be the fan and fan clutch. mine did the same thing
Black318IS is offline   Reply With Quote
Old 12-30-2004, 03:06 AM   #11 (permalink)
Clint_M is an unknown quantity at this point
my 93 318 does it too
from what ive heard from various people / garages / bmw local specialists they all tend to do it at some point, and its usualy the lifters that are causing the noise (tappets), i also heard though that in the engines with VANOS it can be a VANOS noise, i saw someone say something to do with the timing chain as well.
what someone said earlier was right about the tappets tho, they cant be fixed, only replaced = ££.
Clint_M is offline   Reply With Quote
Old 12-30-2004, 01:11 PM   #12 (permalink)
350z
so it wont hurt my car to have that noise? and it wont affect performance?
David
Old 12-30-2004, 02:25 PM   #13 (permalink)
93 325i's Avatar
NO, just an annoyance. Unless it's more than just sticky lifters. I give it a 95% chance that is what it is tho..Very common occurance with the M50 engine.. IF you think performance is being hindered by it then it could be cam, timing chain tensioner, vanos, etc..
My 1993 325i
Old 12-30-2004, 02:29 PM   #14 (permalink)
350z
[snapback]261091[/snapback]
okay cool thanks for all the help guys! so say later on down the road i buy some aftermarket cams... would the clickin noise go away then?
David
Old 12-30-2004, 10:27 PM   #15 (permalink)
flying_junk is an unknown quantity at this point
Send a message via AIM to flying_junk
mine does that too. only after hard cornering for more than five minutes(includes drifting, not accelaration). i dont know why. i was thinking that the oil getrs to like one side of the engine or something and its not spread throughout the engine and some internals make that noise. also, after i crashed my car by drifting, it now does it on startup. i havent really driven it, just started it tho since its still not fixed and drivable.
1992 325i. 5speed.
fun stuff
flying_junk is offline   Reply With Quote
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
e30 325is engine clicking noise mrpauly 3-Series (E21, E30) 11 05-24-2004 11:38 PM
