Engine Check Light - BMW Forum - BimmerWerkz.com
Old 06-06-2005, 11:00 AM   #1 (permalink)
Beanster is an unknown quantity at this point
Does anyone else have this problem? If it is a problem :P
When I first got my car ('94 325) the engine check light came on because my water pump had gone. I took it to get fixed and since it's come back the engine check light doesn't come on when I start the car!! Also when I test the gauges by holding the trip down and turning the key it doesn't come on either.
What's going on? Or am I worring about nothing
Ps when I switch the ignition on I get the following lights under the speedo:
Brake Pads
Handbrake
Transmission
Brake Hydraulics
ABS
They all go aff after a couple of seconds
Beanster is offline   Reply With Quote
Old 06-06-2005, 11:08 AM   #2 (permalink)
Gkamysz is an unknown quantity at this point
The check engine light should come on during starting and go out as normal. If your mechanic didn't notice this, find another. I would certainly question them about it. If you can replace it, do so. If it is still on demand an answer from the machanic.
Greg
Greg
97 328iS, Manual, Stock
Gkamysz is offline   Reply With Quote
Old 06-06-2005, 02:16 PM   #3 (permalink)
93 325i's Avatar
yea the light should come one. Either the bulb burnt out or it was intentionally removed... pull the cluster and check out the bulb situation
Complete mod list and pics:
My 1993 325i
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 09:36 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
