| Electrical Secondary Air Solenoid I have an E36 M52 98 328i and was wondering if anyone could test voltage to the plug in connector that goes to the secondary air valve solenoid. That's the one that has two pin and two vacuum hoses coming off it. The reason is I replaced mine because my pump was not running but bench tested ok but after I replaced it the pump ran for 5 seconds and appears to have burned out. I''m pulling voltage off both sides, 12v and 2.18v with key in run position. I'm not sure if it is bad ground which I checked or a bad DME. Thanks |
