Elect. fault on brakelights E36 1994 - BMW Forum - BimmerWerkz.com
Old 08-08-2009, 02:42 AM   #1 (permalink)
jungle's Avatar
Car: 1994 E36 4 door, Chilli Red 5 speed
jungle is on a distinguished road
Unhappy Elect. fault on brakelights E36 1994
Hi
I have a 1994 E36 series 3 that seems to have a problem with the passenger side brakelight. But it also seems to affect the passenger side park light as well.
Problem is that they only occasionally come on
I have replaced the bulbs thinking it was that, but to no avail.
Could the problem be a loose earth somewhere or is the fuse that works that side only???? as the fuse box has god knows how different fuses in there...
Thanks for any help.
Warren
jungle is offline   Reply With Quote
Old 08-13-2009, 05:11 PM   #2 (permalink)
nnamdi's Avatar
nnamdi is on a distinguished road
Hi Warren, have you read this thread "Attention: ALL E36 owners beware - WIRING PROBLEM" on this forum? It might hold the answer.
nnamdi is offline   Reply With Quote
Old 08-25-2009, 06:45 AM   #3 (permalink)
jungle's Avatar
Talking
Well, it finally did me in and took it to an auto sparky for a look, the bulb holders were not earthing properly, but he discovered the real problem, it was the light switch itself. As it was not going into the park light position and going straight to the headlight position, it was not supplying the proper power needed to the park lights, thus blowing the bulbs out.
After a good going over by them, all is good now, but it cost me $95.00AUD to replace the switch, but better than having a complete meltdown..
Old 08-25-2009, 12:54 PM   #4 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
hmmm....i'm having that same problem.
i'll have to check it out.
carguy13 is offline   Reply With Quote
Fault codes E36 318 I S gabs 3-Series (E36) 2 11-10-2008 03:21 AM
e36 328i tcm fault code coolbox3 3-Series (E36) 2 10-14-2008 11:24 PM
E36 Starting without pressing the clutch? 1994 E36 318i hyper_cool 3-Series (E36) 5 09-25-2007 06:34 PM
92 e36 fault codes? check engine light seven 3-Series (E36) 1 11-15-2006 03:50 PM
