EEpp--> Injection Question!! - BMW Forum - BimmerWerkz.com
Old 07-31-2004, 08:07 PM   #1 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Hey guys, I am (finally) doing a shark injection on my car, however, there is a problem!!
I need to put clamps on the battery to charge it....but there are already clamps on it, from the car itself! And it won't do much good to disconnect the car clamps and charge it...because then the battery will be disconnected from the car itself!! It was my understanding that the battery had to be charging through the entire process...how in the hell do I keep both things going at once?!
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 07-31-2004, 08:53 PM   #2 (permalink)
Deloriant's Avatar
EEP! SOMEONE HELP!
Old 07-31-2004, 08:57 PM   #3 (permalink)
Defector
El Presidente's Avatar
ground the wire on the charger to metal part of the frame, and attach the positive end of the charger to the positive batt term under the hood.
Old 07-31-2004, 10:31 PM   #4 (permalink)
Kevin325i's Avatar
Or if there's room clip onto those ones, they're metal for a reason.
Kevin (President TBEA)
Old 07-31-2004, 10:37 PM   #5 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
all you should need are jumper cables to attach from the charger to the battery...
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 07-31-2004, 10:58 PM   #6 (permalink)
Deloriant's Avatar
ok so i am going to attach the positive jumper cable to the positive part on the battery and then ground the negative jumper cable?
Old 07-31-2004, 11:31 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
ahhhhhh... its easy... put the red one... on the red one... meaning.. possitive on the possitive... and the black to black.. just clip it on top of the battery cable.. that is already there.. dont disconnect anything.. just clip on top of it...
Its there so that if for some reason your car needed more juice... the battery volts wouldnt have any type of flux... yet another reason why you have an alternator... computer dont like un-constant voltage.
1997 E36 M3 1990 E30 325i
Old 08-01-2004, 01:22 AM   #8 (permalink)
Deloriant's Avatar
Gah, I don't know about the rest of you guys, but I noticed no low end difference in power when I injected it. If anything, it's even slower. But up high it's much better...topped my baby out at 150mph tonight, wee!
Problems With Diesel Injection System 525 Tds '97 me and my BMW 5-Series (E12,E28, E34, E39, E60) 0 02-18-2005 04:45 PM
