EEP-2 dash / instrument cluster message (fuel, tem - BMW Forum - BimmerWerkz.com
Old 05-23-2004, 03:19 PM   #1 (permalink)
SkysTheLimit is an unknown quantity at this point
Help!!! Have an '98 M3 with what was intermittent, but is now a permanent problem. Message eep-2 (not eep-1) message is displayed where mileage should be...AND, the fuel, temp, speedo and tach gauges are all "dead".
The problem began in the winter, but when the car warmed up, and ignition switch cycled the message went away and all of the gauges worked. It's been unresponsive for the last month or two, and the hope was it'd "fix itself" once it got warmer out...no such luck.
Does anyone know if it's the cluster, wiring or a "ecu" chip that may be on the fritz? Any ideas/suggestions greatly appreciated!!!
PS My climate control just started acting up (on/off with a mind of it's own...the capacitor problem?). These cars have problems, don't they?! (British Motor Works?) I have less than 50K miles, and the car is maintained/treated fairly well.
Thank you... ghead
SkysTheLimit is offline   Reply With Quote
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Instrument Cluster Questions PMB 3-Series (E46, E90) 4 04-20-2005 11:07 AM
Instrument Cluster Wiring spinkb 3-Series (E21, E30) 6 03-06-2005 08:39 AM
Digital Instrument Cluster komodo 3-Series (E36) 5 08-17-2004 05:41 PM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
