ECU Location - BMW Forum - BimmerWerkz.com
Old 07-06-2006, 11:58 PM   #1 (permalink)
zp619 is on a distinguished road
ECU Location
I was wondering if anyone knew where the ECU is located in a 1994 325i. Thx for the help
zp619 is offline   Reply With Quote
Old 07-07-2006, 12:32 AM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
back left of the engine bay... near the glove box...
http://www.pelicanparts.com/BMW/tech...ip_Install.htm
Old 07-07-2006, 11:00 AM   #3 (permalink)
Thx for the help
Old 07-18-2006, 06:39 PM   #4 (permalink)
Glove Box
I am having some difficulties getting the glove box out. Anyone have any ideas?
Old 07-18-2006, 07:11 PM   #5 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
there are 4 screws that hold the glove box in, and there is a 10mm bolt behind (above) the glove box light.
However, if you're going for the ECU, open the hood and remove the black rubber cover near the passenger's side of the firewall.
Hope this helps.
kestrel325is is offline   Reply With Quote
Old 07-26-2007, 09:41 AM   #6 (permalink)
sunset is on a distinguished road
Hope this helps.
so how easy or hard is it to remove, can you tell me more on how to remove it thanks
sunset is offline   Reply With Quote
Old 07-26-2007, 11:15 AM   #7 (permalink)
thekid's Avatar
If you follow the link above it will give you the pictures and the rest of the article. This part is about 1/2 down or so. ECU/DME are the same thing.
Quoted from the link above:
Installation of a chip is a very easy process. The DME computer is located on the right side of the engine compartment (Figure 1). First, disconnect the battery. Pull back the rubber foam (Figure 2), and you will see the cover that protects the compartment (Figure 3). Remove the cover (four screws) from the compartment and you should see the DME and its harness. Pull back on the small lever on the harness, and you should be able to disconnect it (Figure 4). The DME is held in place by two clips – it should simply slide out (Figure 5). Place the unit on your workbench, and remove the four Torx screws (Figure 6) that hold the cover on. Then, flip the unit over and pry off the six tabs on the bottom. Don’t be too concerned with damaging these tabs, as they aren’t super important in holding the case together. With the tabs detached, pull the metal cover off, and you should see the circuit board (Figure 7). The chip is covered by a small piece of white plastic (Figure 8).
At this point, you might want to put on a static wrist strap, or merely touch something that’s grounded (like a metal lamp housing or a radiator). In all the years of playing with electronics, I’ve very rarely had a problem with static electricity, but once and a while something doesn’t work properly, and you can only guess as to why not. Carefully pop the chip out of the DME unit (Figure 9) and put the new one in (Figure 10). Make sure that the small divot in the new chip faces the same direction as the old one – it is possible to put it in backwards. Seal up the unit, reinstall it, hook up the battery, and you’re done!
Old 07-26-2007, 12:44 PM   #8 (permalink)
thats great,many thanks...
MAF or ECU nookatee 3-Series (E36) 6 05-02-2006 10:00 PM
ECU sleep mode velour 3-Series (E46, E90) 2 11-02-2005 11:58 PM
Location of ICV on M44 318iS engine Rich328 3-Series (E36) 5 09-16-2005 09:55 PM
Plug-in location of outside temp sensor am4tide 3-Series (E36) 4 09-10-2004 11:53 AM
