e36 window problem - BMW Forum - BimmerWerkz.com
Old 07-30-2009, 10:56 AM   #1 (permalink)
opman1 is on a distinguished road
e36 window problem
Hi
i have a 95 2 door 325 is with this annoying issue
the stupid window keeps going up and down and up and down instead of just up when I press the window button to close power windows, this is most of the times but only when closing the windows, sometimes it works normally and nicely goes up like a normal car.
Are the switches dying or what the hell, so frustrating
anyone else have this issue
Thanks
opman1 is offline   Reply With Quote
Old 07-30-2009, 11:13 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
It will be the switch, you may be able to remove it and take it apart and give it a good blast of WD40 or electrical contact cleaner cleaner, you could try to do it from above it may penetrate in to the switch or source another switch.
Basically its sticky contacts with in the switch.
Old 11-30-2009, 06:53 PM   #3 (permalink)
Car: 98 Hell red 328i
skytiger is an unknown quantity at this point
I agree with Marti,
If you only have the problem on one window you could test the theory by swapping the switches over. (Lift your shifter gator and push them up from beneath, unplug them and swap them). If the problem moves to the other window, then you know for sure. You can strip them down and clean the contacts, but be careful. You might as well do them both for good measure.
97 hell red 328i, M3 front, Eibach springs, 18" dished Alutec schnitzer typeII replicas.
skytiger is offline   Reply With Quote
Old 12-01-2009, 03:36 AM   #4 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
ahhh.....window issues.
step 1: buy gasoline
step 2: buy matches
step 3: torch it and buy another car
but seriously window issues suck. good luck.
carguy13 is offline   Reply With Quote
Old 12-02-2009, 02:12 AM   #5 (permalink)
612wade's Avatar
Car: 1994 325IS, black on black, free!
612wade is on a distinguished road
I have a 1994 325is two door. My car used to do this exact same thing. The fix was to lubricate and operate by hand repeatedly, the door switch plunger inside the door jambs. The door thinks its open and the window motor can't tell where the top is. A few blasts of WD40 and all is better. If the buttons are pushed harder, to auto up or down mode, and the window then goes up fine, it's time to clean or replace the window up/down buttons.
612wade is offline   Reply With Quote
Window Problem CiscoKid 3-Series (E36) 2 06-23-2006 09:44 AM
window problem SILVER 325 3-Series (E36) 20 01-06-2006 02:11 PM
1992 E36 Drivers Window Problem whitey_no6 3-Series (E36) 1 06-08-2005 01:00 PM
Window Problem Help 180kbim325 3-Series (E36) 1 02-10-2005 03:10 PM
Window Problem E36 318is Digital318is 3-Series (E36) 5 09-22-2004 09:28 AM
