E36 Tire Feathering - BMW Forum - BimmerWerkz.com
Old 05-09-2004, 04:53 PM   #1 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
I test drove a 95 325is yesterday. The front tires seemed to emit a sound when driving. The owner said that BMW advised him that the tires he bought (Kuhmo with a v groove for wet traction) are not advisable on these cars because for some reason they wear funny? It seemed as if the front of each thread was higher than the rear?
Then my friend told me that he's heard these cars are set up for autobahn speeds, so when driving at normal speeds the tires are actually squated out, then when you get faster and the car lifts a little, the tires actually become vertically straight.
I guess what I'm asking is, What's going on here with this noise?
Thanks!
-Geoff
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 05-09-2004, 06:36 PM   #2 (permalink)
Kevin325i's Avatar
The treadware just sounds like Kuhmos doing. They're cheat grippy tires that don't last very long. Check what tire pressure he's running, then check what kuhmo recomends. Tire inflation is a good place to start for tread ware. Also, the 325is probably have a sport suspension, with more negative camber in the front for handing. Look into if it's got a sports package or anything.
Kevin
Kevin (President TBEA)
Old 05-09-2004, 08:42 PM   #3 (permalink)
uber e36's Avatar
The car does have a sports package... Maybe it's just a bad choice in tires...
Old 05-09-2004, 09:08 PM   #4 (permalink)
Kevin325i's Avatar
Then it's probably just the negative camber from the sports package. If you get the car, those kuhmos won't last you very long so you could get a new set of "better" tires when you wear out the kuhmos. For the money, the kuhmos are pretty good.
Kevin
Old 05-09-2004, 09:29 PM   #5 (permalink)
Car: 97 328is, 93 318is
thinair is on a distinguished road
Send a message via ICQ to thinair Send a message via MSN to thinair
What tires are they exactly?
Kumho Ecsta 712's? If so I know a lot of people with them and run them without problems. They are inexpensive tires, but in no way cheap. They're awesome for the price.
Also, all e36's have more rear camber then in the front, the sports package only drops the car 0.59", which doesn't really affect the alignment all that much, and there is a pretty wide range of camber adjustment in the rear (unless the car is dumped).
Make sure the noise isn't the front wheel bearings.
Nelson Papel
1997 Madeira Violet 328is - Carbonio Intake, Racing Dynamics exhaust, fan delete, ASC delete, M50 intake manifold, M3 Cams, Eurospeed/AA software, 3.38LSD, M3 f&r brakes + MC, Bilstein PSS, Eibach swaybars, BBS RK 17x8" wheels, Toyo T1R (235/40R17) tires, Racing Dynamics K55 kit, full euro lighting, 4300k HID lows, etc..........
<a href='http://www3.sympatico.ca/thinairbikes/bmw.htm' target='_blank'>Click here for more info on my car</a>
thinair is offline   Reply With Quote
Old 05-09-2004, 10:04 PM   #6 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
You tires may be cupped. Is it a rythmic noise? If so, you can look at your tread from a certain angle and see that parts of the tread are actually higher than other. This means either your wheels aren't balanced and the aren't aligned. Check for that.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
F/s E36 Garage Sale!!!!! in_si1ence Classifieds Sell & Buy 0 11-02-2005 04:56 PM
325i Tire Question Ii fobbie 3-Series (E46, E90) 0 03-26-2005 08:09 PM
Excesive tire wear '01 530i 5-Series (E12,E28, E34, E39, E60) 4 03-19-2004 12:45 PM
