e36 sunroof issue - BMW Forum - BimmerWerkz.com
Old 07-09-2007, 08:37 PM   #1 (permalink)
seven is on a distinguished road
e36 sunroof issue
You all have been a huge help in the past now I have another issue that needs attention. My sunroof on my 1993 325is seems to work when it wants to. when working it is perfect the motor and relay in the roof has been changed they were in my crashed e36 and have always worked perfect. Is there a relay I am missing somewhere? Thanks for all your help
seven is offline   Reply With Quote
Old 07-09-2007, 09:50 PM   #2 (permalink)
Linds's Avatar
Linds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond repute
Send a message via AIM to Linds
I had a different issue with my sunroof, but while I was searching for fixes I came across this, which may help you.
DIY- Comfort Relay Repair/ Power Window - Sunroof issue fix - Bimmerforums - The Ultimate BMW Forum
Linds is offline   Reply With Quote
Old 07-11-2007, 06:18 PM   #3 (permalink)
kylek325i is on a distinguished road
Send a message via AIM to kylek325i
if the sunroof works sometimes, and works perfect when it does, do you maybe have a bad ground somewhere? check all the connections to be sure
kylek325i is offline   Reply With Quote
Sunroof Issue bpowers 3-Series (E36) 4 10-17-2010 03:22 PM
BMW 3 series E36 // M3 POWER LSD 2,93 Differential // S14Stock OEM Parts 0 09-05-2006 05:18 AM
Roof Rattles A Bit. Sunroof Issue? ynotony 3-Series (E36) 4 07-18-2005 09:41 PM
Sunroof Issue bmwfool 3-Series (E36) 4 05-18-2005 12:42 AM
