| Hey there,
I had the same problem...
Is your check engine light on? If it is, read the codes...
Do you notice you've been getting poor gas mileage? I had an idle which went up and down, and a check engine light...
I cleaned the ICV out ( check out the FAQ - furious posted it.), and I now have a rock solid idle...
The swap in 02 sensor (located under the car right before the CAT) gave me better performance, better mileage, and a cleaner smelling exhaust...
I reccomend cleaning the ICV first, then if problem persists, look at swapping 02... should be done every 30,000 miles or so anyway... It would be a good thing to do... of course check your hoses first... This goes without saying... Good luck
Cheers,
Steve
__________________ "DUDE, what are we celebrating!!!!????" |
