E36 Rims Rub Wheel Wells - BMW Forum - BimmerWerkz.com
Old 09-29-2004, 11:15 AM   #1 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
I just had some e36 bmw contour rims 17" with tires put on my car yesterday and when i have any weight in the back it will rub the underside of the fender because they are wider than the stock ones. Is the M3 frame different than regular e36? Do i need to jack up the suspension or get the wells redone? Someone please help. Thanks, N
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 09-29-2004, 11:56 AM   #2 (permalink)
Defector
El Presidente's Avatar
You need to roll the fenders.
Old 09-29-2004, 12:10 PM   #3 (permalink)
RedlinedRU's Avatar
I know this sounds stupid, but roll the fenders, does that mean shave them? can i do it myself or........?
Old 09-29-2004, 12:14 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
it changes the fender well's width and soemtimes height, allows for a wider\taller tire. Bodyshops should do this.
Old 09-29-2004, 12:26 PM   #5 (permalink)
Defector
Use a hair dryer and a baseball bat.
Heat up the fender lip with the HD. Then, slowly push out from the rear with the bat, rolling it back and forth under the lip. As you work it, keep applying heat. The lip will eventually have moved far enough out that it won't rub.
The alternative is to take it to a body shop and have them do it with machine that looks like a cross between and english wheel press and tin snips.
Old 09-29-2004, 12:41 PM   #6 (permalink)
RedlinedRU's Avatar
Thanks for the advice man, i will get on it asap. i guess the fender is plastic though right?
Old 09-29-2004, 12:42 PM   #7 (permalink)
Defector
its metal.
Heating it up makes it easier to bend, and also prevents the paint from cracking.
Old 09-29-2004, 12:47 PM   #8 (permalink)
RedlinedRU's Avatar
thanks again, one more question, will it keep relatively good shape when im doing this or is it really easy to disfigure the fender. I will do it slow so that doesn't happen. or TRY to. Man im gonnna blast myself if I mess this up hahah.
Old 09-29-2004, 01:02 PM   #9 (permalink)
Defector
The key is to go slowly and roll the bat. As long as the bat has a good lip on it, you'll be fine.
Old 09-29-2004, 08:14 PM   #10 (permalink)
Power Shifting
Cruzin 323is's Avatar
wouldn't spacers work??
-SOLD..
R.I.P Fast 6
Old 09-29-2004, 08:20 PM   #11 (permalink)
WOT in Reverse
jllphan's Avatar
Rolling the fenders will, I don't think spacers would help, and if I were you I would get firmer springs. It WILL firm up the ride, but between rolling your fenders and this, this will enhance performance.
Just depends on what your going for, show or go.
WTB: M-contour rims e36 m3 stracer Wheels and Tires 2 12-02-2005 03:52 PM
FS: E36 OEM 15" rims with new tires. stracer Wheels and Tires 3 11-03-2005 02:29 PM
e36 wheel for sale SNapper OEM Parts 0 10-18-2005 10:06 PM
E36 M3 Steering Wheel 97alpineM3 OEM Parts 5 10-16-2005 03:38 PM
Steering Wheel Upgrade! Best Sports Wheel for the E36? (judge pictures) Delmarco 3-Series (E36) 14 09-12-2005 05:59 PM
