E36 Over Heating Problem :-( - BMW Forum - BimmerWerkz.com
Old 03-04-2006, 04:39 PM   #1 (permalink)
325iserge's Avatar
325iserge is an unknown quantity at this point
Since the time I bought my E36 I always had overheating problems. In the mornings when the car is cold I start the car to warm it up and about after one min white smoke would come out from exhaust like steam. When I am not driving just standing the temperature lever would go over normal and than when I start driving in will drop to normal. First I changed thermostat and water pump with metal impellers. Also I changed fan clutch. And also I added a liquid into the radiator that temporarily seals the holes in heat gasket because at that time I thought my head gasket might be blown. For about 4 months my car never overheated, and no more white smoke only when I start the car it would shake a little like one of the sparks don’t work but after 30 sec it stops shaking. Than After 4 months it stated overheating again. Once I left my car running and when I came back I saw that temperature level was on red so turn off the car. I tried to start the car it wouldn’t start. I waited for about 5 – 8 min and than the car started but temperature never went down only up even if I was driving. Since that time, I never drove the car I took it straight to the shop. I decided to change the head gasket. When the guy at the shop took motor apart he told me that the head gasket was fine. Also he said that it been changed recently because it looked new. Also he said that there was water in motor oil.
If the gasket is fine what could have been the problem?
How water got into the oil?
Anyone know what else could be wrong?
BMW's are cool & fun.
325iserge is offline   Reply With Quote
Old 03-05-2006, 12:00 AM   #2 (permalink)
WarNox's Avatar
every1 seems to be having overheating probs these days!!!! try searching for other topics, there are plenty around, but not sure if any have your symptoms!
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 03-05-2006, 12:27 PM   #3 (permalink)
Gator is an unknown quantity at this point
If the head gasket is ok, you most likely have either a cracked head or a cracked cylinder block. If the head is still off the block, have it sent out to be Magnafluxed. Magnafluxing shows up small cracks which are not easily visible to the human eye. Hopefully it's the head. If not you can have the block magnafluxed.
There is one more possibility which happened to me long ago when I was racing a Formula Ford. The plug in the intake manifold which is removed when doing a vacuum test was misthreaded so that the threads made a small hole into the cooling passages of the intake manifold. If all else fails, look at all mounting bolts and or plugs that might penetrate the cooling system if improperly bored and taped.
Gator is offline   Reply With Quote
Old 03-05-2006, 05:26 PM   #4 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Do you have to keep feeling the overflow bottle? If you dont that means the coolant isent going anywhere. Have a shop presure test your cooling system. If the presure stays the same than means the cooling system is ok.
You say the car doesnt overheat when driving but it does when stoped. When you drive the air is cooling the car, when you are stoped there is no air flow and it overheats. Maybe you have a radiator that isent flowing right or something else is clogged. How long does the car smoke for? It could be just burning off early morning moisture.
-Serge
theruss1an1 is offline   Reply With Quote
Old 03-06-2006, 09:33 AM   #5 (permalink)
Redbullrr's Avatar
Redbullrr is on a distinguished road
Looks to me like you have a compression issue. If the head gasket was replaced they should have re-surfaced the head and block to ensure proper seal. I had a similar problem, and it turned out to be the head and a bent valve, ended up re-building the motor.
Redbullrr is offline   Reply With Quote
e36 rear view mirror problem/ pop0tart 3-Series (E36) 5 12-12-2005 06:39 PM
E36 325i problem with power steering after doing doughnuts!?!? anar_325i 3-Series (E36) 10 10-12-2005 05:18 PM
PLEASE HELP OVER HEATING PROBLEM bmwboyuk 3-Series (E36) 6 01-27-2004 02:28 AM
e23 heating system problem cyrex 1,6,7,8 - Series and Mini Cooper 0 01-02-2004 05:25 PM
