So.... as you know I have been contemplating this for a while now & was ready to dive in & just do it......I researched threads & found a couple of DIY's......but they were for OBD I vehicles......the end results were good with no CEL's......
with further research, I found out that with the OBD II........ CEL's.......are a problem!
I contacted Turner Motorsports & they said they could reprogram the DME from Auto to Manual Trans mode...2 hours labor @ $95......
& the car would have to be there......5 hour drive from NJ to Amesbury, Massachusetts.......so I'm going to see if I could find someone local to do the reprogramming!
So, I will have to think about this a little more & I have time, because the fundage is coming from my Income tax return.....which will come in March or April........
So, if you want to encourage me to do this.......feel free to do so!
FINALLY! I'm Excited! cant wait! many pics please!
1992 318i Coupe parts car
hi i have a 1997 bmw 328is i am going to swap it to a 5 speed could some one help me
with the reverse light and start up switch i need step by step pics of it being done ill
will pay or donate $100 if you can help me.
Picked up my donor car about a month ago, for my 5 Speed Manual Swap......along with diff.
Car was completely stripped, basically except for the clutch pedal assembly with switches, 5 speed S5D...Z trans, Short shifter, Trans mount, drive shaft, rear diff & CV axles......
Car before it was stripped:
Car was purchased for $700.00 after it was stripped: On it's way to my house for my next project!
finished stripping the donor car for my 5 Speed swap.......
I have been busy ordering all new seals, clutch & pressure plate, bearings, ZHP weighted shift knob, Shift boot, new guibo, shifter bushings, shift pin kits.......etc.
Cleaned trans & diff, replaced all the seals in my ZF 5 Speed & Diff. Input, Output, & Gear rod selector. Replaced trans & diff. fluid with Red Line fluids. Also, replaced all the shift pins & bushings with kits from BMW......
called turner motorsports today in amesbury mass.they said they could not change a auto ecu to manual by flashing it .tulley bmws foreman said the same thing.he told me to buy a manual ecu.then they could align it with the cars other computer.i forget the name?so now i wonder if the abs will work.isnt that part of the trans computer.bimmers are very difficult to mod.
I've got the same thinig going, except my friend owns the part car and is gonna sell me the whole manual driveline...the only problem i can forsee is his is a 325i and mine is a 323iS. should i be concerned?
