So.... as you know I have been contemplating this for a while now & was ready to dive in & just do it......I researched threads & found a couple of DIY's......but they were for OBD I vehicles......the end results were good with no CEL's......
with further research, I found out that with the OBD II........ CEL's.......are a problem!
I contacted Turner Motorsports & they said they could reprogram the DME from Auto to Manual Trans mode...2 hours labor @ $95......
& the car would have to be there......5 hour drive from NJ to Amesbury, Massachusetts.......so I'm going to see if I could find someone local to do the reprogramming!
So, I will have to think about this a little more & I have time, because the fundage is coming from my Income tax return.....which will come in March or April........
So, if you want to encourage me to do this.......feel free to do so!
hi i have a 1997 bmw 328is i am going to swap it to a 5 speed could some one help me
with the reverse light and start up switch i need step by step pics of it being done ill
will pay or donate $100 if you can help me.
Picked up my donor car about a month ago, for my 5 Speed Manual Swap......along with diff.
Car was completely stripped, basically except for the clutch pedal assembly with switches, 5 speed S5D...Z trans, Short shifter, Trans mount, drive shaft, rear diff & CV axles......
Car before it was stripped:
Car was purchased for $700.00 after it was stripped: On it's way to my house for my next project!
finished stripping the donor car for my 5 Speed swap.......
I have been busy ordering all new seals, clutch & pressure plate, bearings, ZHP weighted shift knob, Shift boot, new guibo, shifter bushings, shift pin kits.......etc.
Cleaned trans & diff, replaced all the seals in my ZF 5 Speed & Diff. Input, Output, & Gear rod selector. Replaced trans & diff. fluid with Red Line fluids. Also, replaced all the shift pins & bushings with kits from BMW......
called turner motorsports today in amesbury mass.they said they could not change a auto ecu to manual by flashing it .tulley bmws foreman said the same thing.he told me to buy a manual ecu.then they could align it with the cars other computer.i forget the name?so now i wonder if the abs will work.isnt that part of the trans computer.bimmers are very difficult to mod.
I've got the same thinig going, except my friend owns the part car and is gonna sell me the whole manual driveline...the only problem i can forsee is his is a 325i and mine is a 323iS. should i be concerned?
The driveshaft lenth is the same. The gearing in the differential is different in a Manual, but the housing is the same. Get an M3 diff if you can, as their geared better. 3.15 LSD i think.
mine is a 99 e36 323is his is a 97 325i. sorry my reply took forever ive been workingg like a mofo. now he's not even sure he wants to part it out anymore. anyone know someone parting out an e36 withh a 2.5L?
finished the 5 speed swap a couple weeks ago, its quite a bit quicker with the automatic diff, i love the 5 speed!! i got ahold of a guy in my area that parts bmw's out for a living and it was pretty smooth but frustrating at some points i gotta do the computer end of it still though. the check trans and traction control lights are on and the cruise control doesnt work but its no biggie
Hey congrats...finished mine today..no issues, no CEL's on dash used the Ediabas/INPA software purchased on UK eBay & cleared codes & all adaptations!
Give me a few days & I will contact you to help you out!
I would also suggest that anyone contemplating diagnostics, coding and/or programming on an E36 should get a switchable ADS/OBD interface, as this is the only type capable of accessing both data lines on these cars. The best ones I have found on the market at the moment are available here http://interfaces4beemers.com .
I would also suggest that anyone contemplating diagnostics, coding and/or programming on an E36 should get a switchable ADS/OBD interface, as this is the only type capable of accessing both data lines on these cars. The best ones I have found on the market at the moment are available here Interfaces 4 Beemers .
Will try this when I get my Ediabas/INPA cable back from a friend, I lent it to in New Hampshire. Just when I thought I was done, I will do this even though I am not experiencing any issues at all! No tach revs & idle issues! As far as the 1 bulb in the cluster I removed, which was the A/T bulb. There is no A/T bulb in the stock factory manual car's cluster, so removing it is not a big deal. I do understand the whole driving a manual while having the DME thinking it is a manual. In reality the swap will never be 100% factory OEM, because you are leaving the A/T computer & harness in the vehicle! But I will definitely recode the Engine DME to manual status.
Thanks...David, I was so overwhelmed with the whole thing, more mechanically inclined than computer savvy. Luckily my sister in-law is! I actually was helping this guy out in New Hampshire, Zack, he has a E36 OBD II Convertible. He is doing the swap & video taping the whole thing, he is in the process of editing it right now! So I will forward the info you just shared with me to him. You may have seen some of his DIY video's on youtube, nice guy!
So when I get my software & cable back, I just have go deeper into the INPA files to complete the process of re-writing the DME info to manual mode?
Just PM me with the GM number of your car and I will send you the revised number to write to the Kombi (instrument cluster) and EWS modules using NCSExpert. If you have DIS v44, the process will be fairly straightforward and DIS will then recognise your car as a manual transmission vehicle.
It looks like you have INPA software, which is the diagnostic software used in the factory. You can use it as a basis to install DIS (which is the dealer-level software and can be installed with a guide to repairs). There is a guide to installing DIS v44 with links to software in the Diagnostic Software thread of Bimmerforums.com.
lol...being that, I don't have a garage & only a driveway!
That is exactly where my automatic drivetrain is, in the shed!
johnny
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
