| Yeah, the e36 cars are known to have these problems. If you happened to use a high pressure wand, and you sprayed a good bit where the front windshield meets the plastic trim at the bottom, you could be having an ECU failure. I don't know much about this, but it is a problem area of these cars, and a few of the guys around here have had this issue. I'll see if I can find the thread...
__________________ |
