Originally posted by bad man working@Apr 21 2005, 12:31 PM Yes it sounds like factory PDC (park distance control) the long tone tells you it’s got a fault then it turns its self off it’s probably a faulty sensor get the fault memories check and that’ll tell you which one [snapback]335930[/snapback] |
Thanks for your reply. What do you mean by "get the fault memories check" ?
Is there an easy way to isolate or by-pass a faulty sensor, or identify it? Last night it worked again, but then again stopped working. Clearly a fault, but sometimes is OK.
Thanks
