E36 M3 UUC Flywheel Wrong Clutch - BMW Forum - BimmerWerkz.com
Old 03-09-2004, 01:35 PM   #1 (permalink)
Becherert is an unknown quantity at this point
E36 UUC 8.5lb flywheel. Do you have problems with the proper engagement of your clutch. When you adjust your clutch stop so that it (clutch) will release properly do you sometimes hear a grinding sound (metal contacting revolving clutch body) You could be a victim of being sold the wrong model clutch. There was or is some confusion in the industry about the substitutability of E28 clutches for E34 clutches. Apparently if you have an E34 and need to replace the clutch an E28 clutch will work. But---there is some dimensional difference between the two. It seems the E28 clutch is slightly thicker than the E34. When the e28 clutch is used in conjunction with the UUC flywheel there can be contact between the clutch fork and the clutch.
Now. Ask me how I know this. I will start from the beginning but try to keep it short. I put the flywheel in myself. One huge PITA. I mistakenly hydraulically disconnected the slave cylinder. After reassembly, I never could establish a good position for my clutch stop. The clutch either would not entirely release when the car or the weather was cold or would cause the above grinding sound when the car or weather was warm. Not knowing any better I thought it was air in the system. I did more bleeding than a chainsaw movie----to no avail. Then I replaced the slave cylinder-----to no avail. Then I replaced the master cylinder-----to no avail. I finally called UUC today and Rob explained what the problem is. Unknowing retailers were being sent E28 clutches and selling them with the UUC flywheels. I purchased mine from Bimmerworld but there are other dealers who did the same thing. Bimmerworld is currently deliberating on how to recompense the problem. I will post the outcome. If any of you are experiencing similar problems please post.
Becherert is offline   Reply With Quote
Old 03-09-2004, 01:39 PM   #2 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
GEEZZZZZZ man, talk about a bunch of crap...you had to purchase those extra parts even though you didn't need them because that company F'd up and gave you the wrong parts..... thats bs..... I wouldn't do business with that bimmerworld company anymore for they seem to work under severe negligence. what a crock..
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Clutch And Flywheel 528iguy 5-Series (E12,E28, E34, E39, E60) 2 08-11-2005 10:48 PM
Anyone With 93 325is Running M3 Clutch & Flywheel? BMDub325is 3-Series (E36) 4 01-17-2005 02:13 PM
M3 Clutch And Flywheel theruss1an1 3-Series (E36) 8 11-09-2004 09:03 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
