E36 Exhaust Help - BMW Forum - BimmerWerkz.com
Old 04-19-2005, 12:29 PM   #1 (permalink)
Ram
Ram is an unknown quantity at this point
Hi all. I'm still reasonably new to the e36 owners club. I have an afforadably cheap 316i, not one of the big boys. My exhaust ras gotten rusty and was condering replacing. A friend has an exhaust he does not need but it was from a 325i. Does anyone know if this will still fit on my bimma.
Cheers for looking
Ram
Ram is offline   Reply With Quote
Old 04-19-2005, 01:41 PM   #2 (permalink)
vincentwashere is an unknown quantity at this point
Send a message via AIM to vincentwashere
i dont think so, the headers are different, maybe from the cat-back you can change it.
<img src='http://pic15.picturetrail.com/VOL615/2358567/4641837/67358906.jpg' border='0' alt='user posted image' />
vincentwashere is offline   Reply With Quote
Old 04-19-2005, 02:17 PM   #3 (permalink)
Ram
Cheers for the help. I'm still however, an absolute novice and dont really know what that means. I wanna take it to a garage to get come advice but dont want to get ripped off and wahat to know a bit more about what I'm talking about.
Old 04-19-2005, 02:57 PM   #4 (permalink)
Steinkek is an unknown quantity at this point
The 325 exhaust will not fit your 316 becasue the two engines are completely different. One is a 6 cylinder and the other is a 4.
Steinkek is offline   Reply With Quote
Old 04-19-2005, 03:23 PM   #5 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
[snapback]334919[/snapback]
Well there is more too it then that........ but in this case, your basically right. =)
The exausts found on the M50/M52 will not bolt up, and the hangers are different.
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-19-2005, 03:28 PM   #6 (permalink)
Actually, it will fit. The only differences are that the 316/318 have single pipe exhaust systems and the 325 has a dual pipe exhaust system. All you have to do to make it fit is have a "Y" pipe welded inbetween to connect the dual pipe to the single. It's very simple, a lot of people do this. There are no complications with hangers or mounting positions. Also, with the dual tip exhaust, you will need a new rear valence or you can cut and modify your current one, also a sinch.
Bry
Old 04-19-2005, 03:43 PM   #7 (permalink)
You can put any exhaust on your car you want if you don't mind making modifications.
1996- BMW 328IS
To do list:
Old 04-19-2005, 03:54 PM   #8 (permalink)
Originally posted by NeverLeaned@Apr 19 2005, 02:43 PM
You can put any exhaust on your car you want if you don't mind making modifications.*
[snapback]334943[/snapback]
That's not exactly true. Different cars have different lengths and bends in the exhaust pipe. They would be too short, too long or even bend the wrong way. In this case, everything bolts up perfectly. You just have to insert the "Y" pipe somewhere.
BTW, I installed an M3 exhaust on my friends 318i. It works great. The same cannot be done for the Z3 or 318ti as the rear end is shorter. They require custom made exhaust systems and cannot share the rest of the E36 exhaust systems.
Old 04-19-2005, 04:08 PM   #9 (permalink)
cool.
Isn't the 316, basically a 318 with the rear end shaved off? Your gonna have to cut a bunch, and just eyeballing the two exaust cans they don't look like the brackets are right. But thats what I thought about the 318 brackets before your post too.
1996- BMW 328IS
To do list:
Old 04-19-2005, 04:57 PM   #10 (permalink)
Originally posted by NeverLeaned@Apr 19 2005, 03:08 PM
cool.
Isn't the 316, basically a 318 with the rear end shaved off?* Your gonna have to cut a bunch, and just eyeballing the two exaust cans they don't look like the brackets are right.* But thats what I thought about the 318 brackets before your post too.
[snapback]334954[/snapback]
No, 316 is a 1.6L and the 318 is a 1.8L. What do you mean by the rear end shaved off? Do you mean the 318ti? That's the hatchback model with the E30 rear end, both the Z3 and 318ti have shorter rear ends to the exhaust systems are shorter as well.
He said he was putting a 316i into a 325i, so nothing has to be shaved off though.
Bry
Old 04-19-2005, 06:47 PM   #11 (permalink)
I mean this
http://www.trader.pl/details,131,751...0051505552.asp
I've never seen one in person, but I don't think its a hatch.
1996- BMW 328IS
To do list:
Old 04-20-2005, 07:32 PM   #12 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
Originally posted by NeverLeaned@Apr 19 2005, 07:47 PM
I mean this
[snapback]335025[/snapback]
That's a picture of a hatchback. The 318ti was the only e36 hatchback made in America.
Storamin is offline   Reply With Quote
Old 04-24-2005, 01:20 PM   #13 (permalink)
Ram
So, it seems that putting an exhaust will be possible but may cost a bit. Does anyone know how much at all. Basically, I've been offered a big bore exhaust from a 325i and wont to fit it to my 316i. He only wants £50 for it so dont want to spend a huge amount on fitting it.
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
e36 duel exhaust bmwengineer 3-Series (E36) 9 10-10-2005 09:44 PM
Need Help!1987 325es: Exhaust Leak/runscrappy pettas 3-Series (E21, E30) 12 12-11-2004 05:12 AM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
