E36 electrical problems - BMW Forum - BimmerWerkz.com
Old 12-09-2007, 10:03 PM   #1 (permalink)
avidco is on a distinguished road
I pride myself on being a pretty good mechanic, but I have rarely had to work on my own car after 6 years. I have found that it is easier to ask someone who works on these things everyday. I was driving along yesterday when I noticed my fuel and temp gauges were dead. Also, my brake light circuit warning light started flashing and wouldn't shut off. Other than that, the car ran great.(nothing abnormal) When I got home, I shut it off and tried to restart it. The starter won't make any noise. The lights are all bright, and the car seems to have plenty of voltage. I'm debating on changing the starter, but that doesn't explain the goofy gauge readings.
Has anyone else heard of this happening??
Oh...I have a 1996 328i with 170,000 miles on it. It is an auto.
avidco is offline   Reply With Quote
Old 12-10-2007, 01:25 AM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Starter isn't making even a click? most likely power isn't getting power to it...
maybe there is a bad power lead..... but check for power at the starter and sonoid < spelling is failing me at the moment...
the gauges could be a fuse... brake circuit could be a bulb out or a short check all your bulbs...
1992 318i Coupe parts car
I am Captain Obvious
Old 12-10-2007, 11:39 AM   #3 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
check your brake light switch, if its a bulb you would get brake light failure. its cheap and easy to fix
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 12-12-2007, 06:33 PM   #4 (permalink)
Update!! If fuse #46 blows...it will cause temp and fuel gauges to drop, and the car will not start. After removing entire intake manifold assembly, I figured this out. If you want to mess with someone with an E36....pull that fuse. They will never figure out why their car wont turn over.
E36 trans problems nedd help seven 3-Series (E36) 3 05-27-2007 08:01 AM
Electric problems on E36 - lights flashing!! warsi 3-Series (E36) 10 12-15-2005 06:07 AM
Electrical Problems Duge 3-Series (E36) 12 04-30-2005 05:41 PM
Electrical Problems Edrandall79 3-Series (E21, E30) 4 05-31-2004 11:41 AM
