| You can remove the cluster and replace the bulbs inside. Take out the two torx bolts at the top. I believe they are a T20. Pull out the cluster and there should be 3 connectors back there, dissconnect them. Make sure your steering wheel is unlocked and wedge the cluster out of there. After that there is like 6 torx screws that are around the cluster that you need to remove to get to the bulbs.
Hope this helps.
__________________ - 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD - |
