E36 Coupe Check Control - BMW Forum - BimmerWerkz.com
Old 12-27-2003, 08:37 AM   #1 (permalink)
Morpheous is an unknown quantity at this point
Hi All,
I am driving an E36 323i Coupe with the On Board Computer with Check Control. I have in the past been stopped because I had two faulty lights (one of them being a brake light). I was a bit shocked as to why this did not appear on the Check Control display. It didnt even appear on the dashboard (the brake warning light never appeared).
I have tried testing the system by removing one bulb and pressing the "Check" button. It comes up with the > then a number of blocks then a +<
Is this how it should operate?
Morpheous is offline   Reply With Quote
Old 12-27-2003, 01:31 PM   #2 (permalink)
Defector
El Presidente's Avatar
my car is not CC equipped, but that does not sound correct.
Old 12-27-2003, 03:42 PM   #3 (permalink)
it doesnt does it? i thought so. ok heres something else the car was doing today. There were 3 bleeps that seem to have come from the dashboard area. This happened about 3 times after a reasonably long period (30-40 mins).
Any ideas? Is my car having a nervous breakdown?
Old 12-27-2003, 03:58 PM   #4 (permalink)
FruityOne's Avatar
FruityOne is an unknown quantity at this point
Send a message via AIM to FruityOne
that beeping thing is timer that a previous owner must have set for every 30 minutes or so...like on the hour and half hour it will sound off. and your check thing is having issues with the display. but your computer that checks things like that mayb getting bad as well because my car always tells me my brake lights are out but every single one of them lights up
93 325is - SOLD (white car in sig)
92 325i - 220rwhp/205rwtq (RIP)
02 GSXR 600 - 107rwhp/48rwtq
95 M3 - 220rwhp/205rwtq
President & Founder OF S50 Swap Club
THC the three most powerful letters in my veins...
FruityOne is offline   Reply With Quote
Old 12-27-2003, 05:46 PM   #5 (permalink)
ex owner/admin
Furious's Avatar
the arrows are letting you know you have a problem with something, the "+" sign is to tell you of multiple problems in the system, however it should tell you that you have brake light faliure to at least specify your problem.
Old 12-27-2003, 07:48 PM   #6 (permalink)
I think I know what the beeping is now that you mention it. Because the bulb has failed behind the clock part of the OBC, I had to set the clock by looking closely at the dim characters. I do recall hitting the Memo button (or something) which normally puts the chime icon above the clock (as far as i remember).
I think I better try another OBC in the car (they seem pretty easy to pop out) and give it a try. If its the actual computer that is duff, then I guess I have been given a faulty ultimate driving machine
thanks guys for your reply though. its appreciated
Old 12-30-2003, 02:56 AM   #7 (permalink)
Rodrunner1980 is an unknown quantity at this point
Hi! The OBC on my 1993 318iS does eactly the same when I touch the check control button. I was told that that '>then a few blocks+<' means that everything is OK. But I always doubted that. Now I'm also going to remove a bulb and see what it says.
But what should the OBC normally say when everything is OK?
Rodrunner1980 is offline   Reply With Quote
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
Warning! Cashier's Check Fraud L337E46 Classifieds Sell & Buy 2 03-06-2004 03:04 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
