e36 cooling system - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 12-05-2010, 07:57 AM Thread Starter
beemerbandit is on a distinguished road
e36 cooling system
HELP!!!!!!
my engine overheated this week while trying to get out of a severe snowdrift and most of the fluids exited via the radiator cap.
Now when i run the engine on tickover the temp gauge just keeps going up as far as 3/4 when i lose my nerve (and want to save my engine).
the problem is this;
the engine heats up but the radiator and top and bottom hoses dont,when i run it without the cap the water level rises until it blows a few bubbles and then recedes (the water is still not even warm),there are no noxious fumes coming out the tail end (hopefully the head gasket is intact).
all i can think of is a jammed thermostat but i dont want to go buy one on a maybe as they are 60 pounds sterling!
the heater also blows cold.
any ideas or confirmation would be appreciated
beemerbandit is offline
post #2 of 10 (permalink) Old 12-05-2010, 09:03 AM
Quoted: 1 Post(s)
There may be a big air pocket in the system. Is the coolant pump good?
witeshark is offline
post #3 of 10 (permalink) Old 12-05-2010, 09:09 AM Thread Starter
not sure how to check to be honest,tryin to go with the cheapest option first so will change the stat tomorrow when the parts shop is open
post #4 of 10 (permalink) Old 12-05-2010, 07:11 PM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
Most likely the t-stat stuck closed, not allowing any circulation..........
also, could be a defective water pump, only if the stock OEM plastic propeller water pump is still in there, after they age the plastic becomes brittle causing the propeller to break apart, causing the pump to fail.......if are your going to the stat, you might as well do the pump too........while you are in there, make sure you bleed the system thoroughly after you finish!
jb
____________________________________________
johnnyBgood is offline
post #5 of 10 (permalink) Old 12-05-2010, 07:46 PM
BMW E36 Thermostat Removal And Coolant Flush
Pelican Technical Article: BMW Water Pump Replacement
post #6 of 10 (permalink) Old 12-06-2010, 01:13 AM Thread Starter
Thanks Johnny thats fantastic info and i will certainly make use of it doing the job today(outside in arctic conditions),i will have to take the time to go geet a workshop manual for this car!
thanks again mate you have a good day.
post #7 of 10 (permalink) Old 12-06-2010, 04:14 PM
You are welcome, if you run into problems bleeding it, follow the steps in the link below:
http://www.bimmerwerkz.com/forum/3-s...tum-70619.html
jbg
post #8 of 10 (permalink) Old 12-27-2010, 07:04 PM
caodan2010's Avatar
caodan2010 is on a distinguished road
if ur engine went overheat then that means u need to get a new one, is ur car auto btw?
caodan2010 is offline
post #9 of 10 (permalink) Old 12-28-2010, 09:01 AM Thread Starter
Smile cooling system
thanks but i got away with it,replaced the thermostat and bled the system an now it runs swwweeeet
post #10 of 10 (permalink) Old 12-28-2010, 03:02 PM
Minez210 is on a distinguished road
if ur cap looks worn. then get a new one . fluid shouldnt come out of the cap . its made to withstand pressure.. just a worn cap alone can cause overheating . just a little food for thought. 30 dollar from bimmer dealership. dont get no autozone crap cap
Minez210 is offline
Z4 Cooling System Zedfor Z3 / Z4 /ZM 7 05-18-2010 08:21 PM
Cooling System mhark 3-Series (E21, E30) 2 07-02-2005 09:03 PM
Cooling System Help Needed vmelikRUS 3-Series (E36) 6 04-12-2005 12:30 AM
Cooling System 5_or_Better 5-Series (E12,E28, E34, E39, E60) 1 10-22-2004 11:16 PM
