e36 brakes - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 11-16-2008, 05:39 AM Thread Starter
little jack's Avatar
little jack is on a distinguished road
e36 brakes
Has anyone done their own brakes on e36? I have a 98 323is and I'm trying to remove the rotors but I can't find a socket big enough for the nut that holds it on. Anyone have a clue what size this thing is?
-Jack
little jack is offline
post #2 of 8 (permalink) Old 11-16-2008, 05:45 AM
Help from over the pond
marti5's Avatar
Wow!!! You dont remove the BIG nut!!! Theres a little hex screw:
RealOEM.COM   Part Category Selection
Click on diagram, to enlarge #2
marti5 is offline
post #3 of 8 (permalink) Old 11-16-2008, 08:16 AM Thread Starter
Thanks, I removed the little hex bolt earlier, but the rotor still would not budge, that's why I was thinking the wheel bearing nut had to come out. Is there a trick to loosening the rotor after the little retaining screw is out? or do I just muscle it off?
-Jack
post #4 of 8 (permalink) Old 11-16-2008, 12:41 PM
marti5's Avatar
Hammer!!! but do not hit the nut or cap, just tap/ bang around the centre, before you put the new one on clean the surface, you dont need to do the hex nut up tight it only holds the rotor in place until you get the wheel back on.
All the best.
marti5 is offline
post #5 of 8 (permalink) Old 11-16-2008, 01:15 PM
Science Roolz!
SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all
I've done this job 6 times, this is the hardest part, every car I've done it on the rotors were frozen on the hub, it's a bitch, but hammering and man handling it is the only way pretty much. Just keep going, if you are replacing the rotors then you don't have to worry about damaging them, just keep at it, they'll eventually give.
2011 Mazda2
1990 Mazda Miata
SHAHAB323IS is offline
post #6 of 8 (permalink) Old 11-16-2008, 04:48 PM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
This should help to.......
BMW E36 Replacing Brake Pads And Rotors
johnny,
____________________________________________
johnnyBgood is offline
post #7 of 8 (permalink) Old 11-16-2008, 05:07 PM
PrInG's Avatar
PrInG has a spectacular aura about PrInG has a spectacular aura about
Send a message via AIM to PrInG
If all else fails try heating it up.. That is always teh answer. Honestly heat it with a torch.. Be sureto stay away from anything that will melt but for sure, if you can't get it off by just beating it, add a little heat to the equation= ) good lcuk
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline
post #8 of 8 (permalink) Old 11-16-2008, 06:30 PM Thread Starter
Thanks guys, got it now, had to soak it 3 times for an hour each with wd40. That combined with hammering around it finally broke them loose. You guys are great. Thanks again.
E36 brakes? BMW Kraft 3-Series (E36) 13 06-26-2007 01:38 AM
E36 328is Brakes Upgrade socalguy 3-Series (E36) 6 02-21-2005 08:54 PM
E36 Brakes Supergnome325i 3-Series (E36) 5 02-05-2005 11:07 AM
Looking to upgrade E36 brakes - any suggestions? bbaron M-Series (M1, M3, M5, M6) 5 10-13-2003 11:53 PM
e36 brakes? wki 3-Series (E21, E30) 3 10-08-2003 02:19 AM
